Mileage difference - is 7K a big deal?
Old Nov 1, 2016 | 04:29 PM
James Harden's Avatar
James Harden
Originally Posted by Miskonduct
Do you have photos of your car that you wouldn't mind sharing?
Old Nov 1, 2016 | 08:43 PM
Miskonduct's Avatar
Miskonduct
Originally Posted by Selym
So you don't have access to the service history, then.
Maybe a dealer service department can look up the VINs to see the service histories.
Check to see that the recommended maintenance was done at the recommend intervals. Check the owner's manual. It's available at the Infiniti US website.
So I'm going through Carmax and they don't have any of the service records from the previous owner. Only the vehicle history records from Autocheck.
Old Nov 1, 2016 | 09:06 PM
Selym's Avatar
Selym
I'd check with an Infiniti dealer to see if they can run the VINs through their system.
Old Nov 1, 2016 | 10:16 PM
Miskonduct's Avatar
Miskonduct
Is it odd that both vehicles, located at the same Carmax, same packages and condition and are priced the same, despite mileage being a bit different?
Old Nov 1, 2016 | 10:18 PM
Selym's Avatar
Selym
Why is that odd? 7000 miles is nothing. I do that in 6 months.
Old Nov 1, 2016 | 10:22 PM
Miskonduct's Avatar
Miskonduct
Not saying it is at all. Wasn't sure if that mileage would justify a price difference or not. I can see why it wouldn't.
Old Nov 2, 2016 | 11:44 AM
AUR11's Avatar
AUR11
I would probably look elsewhere other than carmax. They tend to be over priced on cars like these.
Old Nov 2, 2016 | 02:04 PM
Miskonduct's Avatar
Miskonduct
Thing is, I've been looking for the past 6 months. And these actually are priced okay - just below KBB.
Old Nov 2, 2016 | 06:51 PM
Miskonduct's Avatar
Miskonduct
So I was able to get maintenance records for both and they were maintained well. It looks like the LP sedan met more of the scheduled mile checks, but overall nothing crazy between the two.
I noticed the LP sedan had a couple notes for:
Tire(s) balanced
Tire(s) mounted
Two tires mounted
I'm guessing that just means they rotated the wheels side to side? Since it's a staggered setup, this doesn't usually happen does it?
Old Nov 2, 2016 | 06:57 PM
Selym's Avatar
Selym
Tire(s) balanced
Tire(s) mounted
Two tires mounted
"Tires mounted" generally means tires were mounted on rims. "Tires balanced" generally means the tire/wheel assembly was balanced. In other words, tires were probably replaced.
Are these cars you're considering AWD or RWD? If the latter, it's a staggered setup. If the former, it's a square setup.
Old Nov 2, 2016 | 07:06 PM
Miskonduct's Avatar
Miskonduct
So it looks like the first time the tires mounted and balanced showed up was at 11K and then again at 23K.
And these are RWD cars.
In general, it doesn't look like anything stuck out too much from the records.
Old Nov 2, 2016 | 09:31 PM
Selym's Avatar
Selym
Oil changes?
Old Nov 2, 2016 | 10:58 PM
JSolo's Avatar
JSolo
Just say no!!!!!
~11K miles between tire changes seems excessive even on a rwd. Sanely driven, the summer tires should last 15-20K.
Old Nov 3, 2016 | 03:42 AM
  #29
Miskonduct's Avatar
Miskonduct
Oil changes?
Both were kept up with regularly.
  #30
Miskonduct's Avatar
Miskonduct
Assuming that's what it was, yeah, I would agree.
