Humming Noise at Highway speeds
Old Oct 24, 2016 | 12:52 PM
John_37x's Avatar
John_37x
Driving at highway speeds I notice a rhythmic humming emanating from the car but I can't tell where it is coming from. It seems to have a consistent cycle of humming for a couple seconds then stops for a couple seconds and becomes unnoticeable say under 50-55 mph. Any ideas what may be causing this?
Old Oct 24, 2016 | 01:28 PM
qmantran's Avatar
qmantran
Wheel bearings are known to cause humming. However they are usually noticeable at all speeds and get louder as speed increases
Wheel bearing?
Old Oct 25, 2016 | 11:37 AM
AUR11's Avatar
AUR11
my car did this, it was the wheel bearing. I replaced both with the timkin ones from Rock Auto and it went away.
Old Oct 25, 2016 | 03:22 PM
John_37x's Avatar
John_37x
Thanks for your replies, I was thinking it could be a wheel bearing. I had one replaced on my 2003 G35 MT but the noise was much louder. Maybe the bearings not that bad yet and thats why I don't notice it at lower speeds. This morning I didn't notice it at all on the highway. Do you know if the warranty covers it, got 2 days left.
Old Oct 25, 2016 | 09:13 PM
SomeName's Avatar
SomeName
Bearing noise wouldn't come and go like that.. Sounds weird. The best way to identify a bearing is to drive at constant speed (not to fast) and swerve side to side. As the weight shifts to the side with the bad bearing, the noise will get louder.
Old Oct 26, 2016 | 01:58 PM
JSolo's Avatar
JSolo
Just say no!!!!!
My old camaro used to hum. It would start at ~60mph and be really bad by 75mph. I replaced the steel drive shaft with an aluminum unit. It didn't remove the hum entirely but shifted it over by ~15-20. It would not start at 75ish and be really bad around 90.
I've not experienced this at all with my G and it's been through the full gamut of speeds under triple digits (after all, it's not about straight line speed but cornering speed/ability).
Old Oct 26, 2016 | 05:47 PM
Victory's Avatar
Victory
Had to do a front wheel bearing at 34k mi. If you find it's worse or better going around a curve, that's what it is
Old Oct 27, 2016 | 04:41 AM
ZahyMatar's Avatar
ZahyMatar
I noticed this as well, anyone have a link for the hubs I need for a 2012 G37x Sedan?
Old Oct 27, 2016 | 08:22 PM
John_37x's Avatar
John_37x
Thanks all for your input. I took it to the stealership and they replaced the faulty bearing - today was the last day of my warranty too!
Old Oct 28, 2016 | 12:18 AM
ZahyMatar's Avatar
ZahyMatar
Did they replace it under warranty?
Old Oct 28, 2016 | 10:10 AM
John_37x's Avatar
John_37x
Yes they replaced it under warranty. They also will be replacing the ashtray because the lid will not stay shut and they are replacing the wood trim around the shifter because there is a hairline crack in it!
Old Oct 28, 2016 | 11:03 AM
ZahyMatar's Avatar
ZahyMatar
I meant to ask if you had the power train warranty
Old Nov 1, 2018 | 02:09 PM
Erick Cardenas's Avatar
Erick Cardenas
Buzzing sound at high speeds
The sounds seems to kick in at 5 or 6th gear. Sounds like a buzzing electricical noise as if the alternator is over charging or a bad ground. I turned off my radio, still the noise kicks in when I slightly or press on the gas pedal. When I let go it goes away. Any ideas or hints ? Thanks
Old Nov 1, 2018 | 02:19 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I don't hear a hum, but more so a high pitched sound around 70-75 mph. It too goes away when I lift off the throttle. Normally the stereo is turned on so I don't hear it. In another decade or so i'll be too old to hear high pitch sounds anyways, so problem will fix itself
