Upgrading the center console to the newer G
Old Jul 7, 2016 | 09:23 PM
08STLX's Avatar
08STLX
I have a 2008 so it comes with the waterfall style center console; it's okay but I really like the newer style. My wee mind thinks I can retrofit but I am curious as to how much I will need to buy.
I will need to replace both pieces one and two correct? Does that falling off trim on the side need to be replaced as well?
Just curious if anyone has toyed with this before.
Thanks all
Attached Thumbnails Upgrading the center console to the newer G-2012_infiniti_g37-pic-923260683707705279-1600x1200.png   Upgrading the center console to the newer G-img_1728.jpg
Old Jul 8, 2016 | 01:08 AM
iCrap's Avatar
iCrap
I'm sure it'll fit but why would you want it? the old one flows so much nicer than the new one. I always wondered why they changed it and made it worse.
I think you'll have to change more than those pieces. you need to change the seat heater part too, and possibly even the arm rest.
Old Jul 8, 2016 | 01:57 AM
Elco's Avatar
Elco
I have both variants. On the convertible i have the old style console.On the sedan i have the new style. The old style is much much better.
Old Jul 8, 2016 | 07:28 AM
08STLX's Avatar
08STLX
Personal preference.
Old Jul 8, 2016 | 09:59 AM
zer099's Avatar
zer099
You will need the entire 2010+ center counsel and shift surround. You will have to either get the rear vents tubes or custom your own to work with the new counsel and they are different shaped between the two styles. You will also need to custom some holes for whatever option of wiring you have under the arm rest as well. Your trim will also no longer match so you might want to consider vinyl wrapping your new center pieces and stereo as well. Lastly if the counsel you source does not come with the pieces that replace the "waterfall" part of the center section you will need to source that as well (its part of the old shift surround, but on the 2010+ its a separate piece).
Personally I like the flow of the 2009s (the "waterfall") but also like aspects of the 2010+. I've picked up the parts needed to make a Frankenstein version but haven't made time to do it yet. I can tell you that just a straight swap over will be much easier as long as you get all the parts for it.
Old Jul 8, 2016 | 10:43 AM
jomama22's Avatar
jomama22
All I know is the side chrome trim on the newer ones Creek like a **** when it's below 20 degrees of so. You touch them and it sounds like the plastic may explode lol
Old Jul 8, 2016 | 11:23 AM
g37Frost's Avatar
g37Frost
Sounds to me like a cool project, if you can make the wiring and such work. If you attempt it, please keep us posted with pics and such. I'm very curious to see if it works.
Old Jul 10, 2016 | 10:16 PM
AARONHL's Avatar
AARONHL
I like the heated seat switches more than the dials
Old Jul 10, 2016 | 10:28 PM
WillCo1's Avatar
WillCo1
Honestly, compared to the new Q50/60, the center console on our cars looks sooo dated. I was in the dealership a couple weeks ago and they had the new Q50 sedan and the G37 Coupe (q60) and the center console is what makes the car look the most dated. That and the giant red tail lights.
It would be sick if we could somehow upgrade to the double screen.
So I wouldn't really worry about 2008 style VS newer. They are both quite old. Lol.
Old Jul 10, 2016 | 10:56 PM
ZahyMatar's Avatar
ZahyMatar
But the G tail lights are awesome. At least you can tell it's an Infiniti from the rear, unlike the Q50 which looks like a Hyundai or Mazda 6.
Old Jul 10, 2016 | 11:52 PM
iCrap's Avatar
iCrap
I hate the Q50 center console... too much glossy stuff. I really do think the 08 style looks better and just flows nicer. no hard edges or weird lines.
Old Jul 21, 2024 | 05:04 PM
Jmoney11484's Avatar
Jmoney11484
Any info on this ? Was going to attempt this evening
Old Jul 21, 2024 | 05:29 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Been there/ done that. Only "issue" will be retrofitting the seat heat switches and with a little dremel work that's not a big deal.
Eccentricfox
Jul 28, 2022 07:12 PM
MikeKiloDelta
Dec 26, 2013 07:33 PM
GoBeau
Apr 15, 2012 06:45 PM
prutkows
Apr 5, 2008 04:14 PM
corruptor
Nov 22, 2007 12:14 PM
