Exhaust diameters
Old Apr 11, 2016 | 10:21 PM
Mattlorentzoe's Avatar
Mattlorentzoe
Exhaust diameters
I just realized I have 2.5 intake, 2.5 throttle body, ported plenum, ported lower, stillen headers, and 2.5 hfc. But went cheap on exhaust (topspeed pro 1 cat back) and its 2.36 not quite 2.5.
Is it worth the upgrade to 2.5? Or is the difference of 0.14 of inch not something to worry about? I'm pleased with the sound of pro 1 but on the hunt for some extra power. Figured I'd ask around the forum, I would think the 2.5 would make more power just not sure if it would make 1hp or 10hp more.
I couldn't find what Topspeed claims to make for a 2.36 but as reference stillen claims 18 with their 2.5
Help!
Old Apr 11, 2016 | 10:27 PM
MaQG37's Avatar
MaQG37
Short answer: no , it's not worth the extra money.
Old Apr 12, 2016 | 09:36 AM
ryanwhite74115's Avatar
ryanwhite74115
5" straight pipes or go home.
Old Apr 13, 2016 | 10:35 PM
Mattlorentzoe
Lol. Ended up getting the stillen. Hope it fits the X sedan!
Old Apr 14, 2016 | 12:36 PM
slartibartfast's Avatar
slartibartfast
Exhaust does not have to be as large at the intake due to working pressures. You have over 200 psi pushing spent exhaust when the exhaust valve opens. Pressure drops quite a bit by the time you reach the muffler, but still... Absolute best intake working pressure you can get on a naturally-aspirated engine is 14.7 psi.
Old Apr 15, 2016 | 06:32 PM
SonicVQ's Avatar
SonicVQ
I assume you mean 14.7 psia (absolute, or about 0 psi gauge)
A stock G37 at wide open throttle has about 1.8 inches/Hg (0.9 psig) intake vacuum. (well, that is what I happen to recorded today for a different reason )
Old Apr 15, 2016 | 06:47 PM
slartibartfast
I meant dP, i.e. the amount of pressure head to push air into the cylinder. The difference of a perfect vacuum in a cylinder to atmospheric pressure. Realizing, of course, that perfect is unattainable and real engines have reversion to further lower dP.
Hugh Anderson
Apr 24, 2017 07:10 PM
willstophe
Apr 19, 2016 01:02 AM
b_dupy
MODDING 411
Apr 12, 2016 09:59 AM
importdriver27
Apr 9, 2016 08:33 AM
