Old Apr 20, 2023 | 09:11 AM
  #9361
If the main diff bushing is blown, and you're relying on the diff brace to keep things solid, then aren't you putting a lot of stress on the diff housing bolt(s) that the brace is connected to?
I'm no mechanical engineer, but it seems to me the diff brace should complement the situation, and not compensate for a problem.
My car has solid poly diff bushings (Whiteline) and a diff brace (Bell). There's no wiggle back there at all. I've also got Z1 poly motor mounts up front, with a FSTB up on top, a lower cradle brace down below, and a poly trans mount in the middle. Truth be told, it's not a luxurious ride anymore, the NVH is somewhat visceral. Usually that's pretty awesome, but sometimes it can be a bit much.
Old Apr 20, 2023 | 11:22 AM
  #9362
thescreensavers's Avatar
thescreensavers
Originally Posted by Sea Stories
@thescreensavers interesting. I have a few questions:
1. How long did the epoxy last?
2. How did you know if failed?
3. Are you saying that, with the diff brace installed, it doesn't matter if the bushing is bad?
Thanks,
Sea Stories
Cant really remember where I saw it but for some it did not last, im sure it depends how good of a job you do. With the diff brace the bushing isn't loaded as much anymore so pretty much a permanent fix without added NVH.
Yup you are 100% correct, since the Diff brace is solid and the bushing is soft most of the load is now going through the brace. At first I was skeptical about using a brace because of that but since its been on the market for a bit now without any reported major issues seems like its not a big deal. Just need to make sure you torque your bolts correctly.
Old Apr 22, 2023 | 12:57 PM
  #9363
rotarymike's Avatar
rotarymike
Moderator in Moderation
I think my calculations for filter size were a little off.
alls well that ends well though.
Old Apr 22, 2023 | 05:42 PM
  #9364
STownSaint's Avatar
STownSaint
Took a trip to the suburbs, so naturally packed my 2 buckets. First wash since the deluge of pollen. Also tinkered with my turn signals more to figure why the heck my brake and license plate lights were all blinking when I signaled…
Strongly considering leaving my car out here, to finally sit in a garage. Using the G less and less these days, so probably worth it to stash it away for a while. And keep the battery on a tender, which has been a nagging issue lately
Old Apr 22, 2023 | 11:17 PM
  #9365
iCrap's Avatar
iCrap
Thanks,
Sea Stories
I went from blown bushing (1-2 shift had a very bad clunk, rear end hopped and caused traction control to come on) > epoxy fix (slight clunk, no tcs) > diff brace (no clunk, no TCS) > diff brace w/ poly bushings (didn't really notice much difference.
So my suggestion to you would be to epoxy + diff brace. The bushing was an absolute PITA job and I have a lift.
Old Apr 23, 2023 | 05:54 PM
  #9366
SupraOfDoom's Avatar
SupraOfDoom
The Bell racing diff brace didn't fit with my exhaust, but I want to give the Z1 version a chance. But yes that rear bushing is one of the hardest jobs I've done, and easily the most bruised I ended up lol.
Old Apr 23, 2023 | 08:14 PM
  #9367
thescreensavers
Doing the Subframe bushing on a Sedan is definitely a PITA, would be easier to just drop the sub frame than doing it on the car
Old Apr 24, 2023 | 09:25 AM
  #9368
Sea Stories's Avatar
Sea Stories
That's what I was hoping to hear!
Old Apr 24, 2023 | 12:10 PM
  #9369
BULL's Avatar
BULL
Moderador
I work with T clamps left and right.
LEFT AND RIGHT!!!!!!! And look at this.....
All this time, all the clamps, all of the brackets made...
And it's not like you dont get 2 inches of thread extra per clamp once tightened that you purposefully cut for looks and attach a bracket to the pipe because it hangs
As simple as this is thank you for the trick!
Old Apr 24, 2023 | 12:18 PM
  #9370
You used the t-clamp bolt to connect the frame bracket? That's pretty clever.
Old Apr 24, 2023 | 04:04 PM
  #9371
rotarymike's Avatar
rotarymike
That's actually MY car, with the new 2.75 CAI...
@BULL Using T-bolts for support as well as clamping is pretty common in aerospace.
Old Apr 26, 2023 | 12:07 PM
  #9372
Josh South's Avatar
Josh South
Sprayed some cerakote on my intake tubes.
Old Apr 26, 2023 | 06:51 PM
  #9373
AnotherVQ's Avatar
AnotherVQ
Another oil report:
Old Apr 26, 2023 | 07:17 PM
  #9374
thescreensavers
now we need an engine bay shot I am a fan of less polished metal!
Originally Posted by AnotherVQ
Another oil report:
Nice report! I think after another clean one you can easily do 5k OCI with T6.
What was the oil you used before?
Old Apr 26, 2023 | 07:18 PM
  #9375
AnotherVQ's Avatar
AnotherVQ
Why 5k specifically?
All tests in screenshot are same oil.
