Old Feb 10, 2021 | 07:02 AM
  #8416
rotarymike's Avatar
rotarymike
Moderator in Moderation
I've used one like this for years:
The pic comes from Harbor Freight, but mine are from a tool truck back when I was wrenching on airplanes (so maybe ~1999?) The silver safety bars help, and I have a chain I wrap around the whole deal so if one pops off under pressure it doesn't launch into orbit.
Old Feb 10, 2021 | 08:36 AM
  #8417
tsuintx's Avatar
tsuintx
I had a minor oopsie moment with spring compressors many many years ago and right then and there I decided that if I need to change them on a strut, I will take them to a shop to get done. One of the few things I don't want to do myself and I'll gladly pay the price. Not worth it to me
Old Feb 10, 2021 | 08:50 AM
  #8418
BoomerSpeed01's Avatar
BoomerSpeed01
Originally Posted by canuckcoupe
Swift springs from Touge Tuning, a local performance shop in Toronto
Whiteline sway bars from Summit: https://www.summitracing.com/int/sea...g&fr=part-type
Meagan Racing strut tower brace off ebay.
What are the sway bar links and tie rod ends?
Old Feb 10, 2021 | 09:45 AM
  #8419
BoomerSpeed01
You would need to have both on opposite sides of the spring to keep it compressed evenly, correct?
Old Feb 10, 2021 | 09:48 AM
  #8420
backman_66's Avatar
backman_66
That is correct! I just did my springs using a tool like this. Just alternate sides as you compress the spring.
Old Feb 10, 2021 | 10:29 AM
  #8421
rotarymike's Avatar
rotarymike
Yes. The chain around the whole thing keeps them from flying off if something slips - never happened to me, but I've seen it happen so. Chain.
For *some* cars, you can just unbolt the top hat attached to the car, jack the car up and let the car itself decompress the springs. Of course, you may run into the issue that there's not enough suspension travel to fully decompress the spring which leaves you stuck. Not that that has ever happened to me, no sir.
Old Feb 10, 2021 | 08:39 PM
  #8422
canuckcoupe's Avatar
canuckcoupe
The 2 pairs of sway bar links come with the Whiteline sway bar kit.
There are no tie rod ends in that picture.
Old Feb 11, 2021 | 02:02 PM
  #8423
BoomerSpeed01
Ahh ok, just saw the two pairs and assumed they were both for the front end. Spaced on the fact that you got both sway bars.
I know the beefed up sway bars "stiffen things up", but can someone explain in noob terms what it does to the driving dynamics? lol Like do they effect the ride, body roll, etc..
Old Feb 11, 2021 | 03:20 PM
  #8424
backman_66's Avatar
backman_66
There's a good discussion of it here:
https://grassrootsmotorsports.com/fo.../162127/page1/
Sway bars only work to stiffen up the spring rate while turning. You'll also feel extra harshness when going over bumps because it stiffens up the connection from 1 side of the car to the other. They will reduce body roll when turning. You can also buy adjustable sways to fine tune your understeer / oversteer balance. This is my understanding which may not be 100% accurate.
In that thread I linked, they basically say that a racecar will use stiffer springs and small / no sways. For a DD, you'll want to only stiffen the springs up to the point that you can tolerate for comfort.. but you can do more of this with sways for a less overall harsh ride.
Old Feb 12, 2021 | 01:15 PM
  #8425
tsuintx's Avatar
tsuintx
Been stupid cold in Texas for a few days now and it's only getting worse and the x has just been sitting for a few days. Decided to go see what it says and of course it didn't say anything. Battery has kind of been on the fritz ever since I bought it, but looks like this cold weather finally did it in. Put a charger on it for a quick charge and it barely came to life. Guess it's time for a new one... Pretty sure it's at least three years old anyway.
Old Feb 12, 2021 | 01:25 PM
  #8426
BoomerSpeed01
A car battery should last for more than just a few years... Did it sit for a long time or something? As in weeks or months?
Old Feb 12, 2021 | 01:37 PM
  #8427
tsuintx's Avatar
tsuintx
In Texas the average life cycle of a car battery is around 4 years. Heat kills them here more than cold, actually. I only bought the car earlier this year and I think I saw date code of early/mid-2017 on it.
Old Feb 12, 2021 | 01:40 PM
  #8428
You know what else kills a battery after a year or two? When normal ownership means having the car sit for weeks on end while parasitic things like a remote starter or a theft system slowly suck the life out of it.
Old Feb 12, 2021 | 01:52 PM
  #8429
tsuintx's Avatar
tsuintx
Haha! Hell yeah they will. Modern vehicles never really sleep, anyway. Mine never sit weeks on end, though. The G sat for maybe 4-5 days and sure, maybe there's some parasitic loss somewhere, but the battery is also old-ish, so time for a new one.
  #8430
BoomerSpeed01
That's true. Did you use those examples because you have those on your G? I know you've mentioned especially now during winter your G is garaged a lot of the time.
In Texas the average life cycle of a car battery is around 4 years. Heat kills them here more than cold, actually. I only bought the car earlier this year and I think I saw date code of early early mid-2017 on it.
I'm in Indiana so I didn't know about the heat killing batteries. Makes sense though. Makes me want to move to Tennessee or the Carolinas even more knowing that lol
