Old May 14, 2016 | 09:49 AM
  #496
SomeName's Avatar
SomeName
Originally Posted by ShuuraRG
I've just swapped it out, but didn't do anything to prevent power loss. I'll need to reconfigure my steering wheel and seat settings, but all else is working as expected.
Losing power is my greatest nightmare! I think I would have to enter the password to the satellite radio, which I don't have. It just works
I'm curious, what is the logic behind putting a deep cycle battery in a car?
Old May 14, 2016 | 11:24 AM
  #497
Lego_Maniac's Avatar
Lego_Maniac
I don't recall losing any settings when I swapped batteries
Old May 14, 2016 | 02:52 PM
  #498
guy from norcal's Avatar
guy from norcal
I didn't loose any setting either.
Old May 14, 2016 | 03:33 PM
  #499
RxRyanM's Avatar
RxRyanM
But did you tighten any settings?
Old May 14, 2016 | 07:31 PM
  #500
PG-v36_6MT's Avatar
PG-v36_6MT
Southbend Clutch Stage 2 Daily w/ Quiet Disc, Z1 Nodular Iron Flywheel (~25lbs), ZSpeed HD CSC, ZSpeed Insulated SS Clutch hose, Motul Gear 300 fluid.
Old May 14, 2016 | 07:51 PM
  #501
Ish2011g37x's Avatar
Ish2011g37x
Before and after
Before
After also hotckis sways added and stop tech brake pads
Old May 14, 2016 | 10:25 PM
  #502
Dembflyr's Avatar
Dembflyr
Cleaned her all up for a special cars & coffee tomorrow.
It's being held at the Indianapolis Motor Speedway Museum.
Old May 14, 2016 | 10:41 PM
  #503
dwb993's Avatar
dwb993
Driving to Florida for the week. Made it to Savannah area before Laurie had to stop. Car is performing flawlessly...very comfortable even this old man's back! Yay sport seats!! About 26 mpg so far...likely a bit higher.
Old May 14, 2016 | 10:43 PM
  #504
PNW_IPL's Avatar
PNW_IPL
Originally Posted by Ish2011g37x
Before
Nice man. Really considering the takeda being in washington like that the filter can be covered. How do you like?
Old May 15, 2016 | 05:13 AM
  #505
Falker11's Avatar
Falker11
nice! you DIY'ing the install or letting a shop take care of it?
Old May 15, 2016 | 07:54 AM
  #506
PG-v36_6MT's Avatar
PG-v36_6MT
Thanks! There's no way I'm dropping a trans on jack stands lol. If I had access to a lift, I might of attempted it, so I had a shop take care of it.
Old May 15, 2016 | 11:57 AM
  #507
Nice! Bet your tires are getting scared
Old May 15, 2016 | 05:33 PM
  #508
SomeName's Avatar
SomeName
Installed led fogs. I guess I should have asked if the right side was a PITA. Wasn't expecting to have to jack it up. Now I just have to wait 4hrs for the sun to so down.
Old May 15, 2016 | 05:55 PM
  #509
Nitro15's Avatar
Nitro15
SomeName why did you have to jack it up? Do you have a sedan or coupe? Just curious because I plan on replacing my fogs soon with leds and was under the assumption that you can just pop out the clips and pull back the wheel well lining and replace the bulb. Thanks.
Old May 15, 2016 | 06:28 PM
  #510
Calidoso's Avatar
Calidoso
Finally finished up the Interior Trim Wrap. I think it came out pretty well.
