Old Mar 14, 2017 | 08:23 PM
  #2326
VIVID's Avatar
VIVID
Pyroclastic Flow
What are you trying to say? Did you finally go gloss black instead of bronze on those late-model sport-coupe rims? Good. It suits the car so much better with the roof, front grille, window trim and tint.
Unless that's not what I'm seeing, in which case... um, nevermind.
Or are you complaining that we're going to get 12" of snow tomorrow?
No. Actually, last week I put my forged Rays on and....with the drop in temperature and pending snow, I went back to the late model coupe wheels. Which are still finished in sunken treasure. They look black sometimes and when the light hits them right, some gold peeks through.
Good luck in the snow!!
Sean
Old Mar 15, 2017 | 09:01 AM
  #2327
woofersus's Avatar
woofersus
Back in 2013, I bought a single, 4" HPS coupler spec'd at 70mm. (Then I cut it in half, one for each side.) IDK if 70mm represents ID or not, but that's what I've got.
Any idea what the chances are that my Z1 post-MAF tubes are around the same thickness as that HPS coupler? I can't seem to find any specs on size for those. (or any other similar products)
They fit tightly enough that I've been running clampless for a clean look, but those aluminum clamps look nice enough I may add them anyway.
Old Mar 15, 2017 | 09:09 AM
  #2328
There's no way for me to know that. I suspect the Z1 tubes are a thicker material than typical couplers, simply because of the more substantial nature of their application.
I wouldn't run "clampless", regardless of fitment. That doesn't seem right at all.
As for these P2M clamps... they're really inexpensive. You've got nothing to lose except $7 each, time and effort.
Old Mar 15, 2017 | 10:00 AM
  #2329
Nico-derm's Avatar
Nico-derm
Tail-as-Turn modules showed up today, looks like I have something to do while I have a beer after work lol
Old Mar 15, 2017 | 10:29 AM
  #2330
Want a tip? Use a strip of indoor/outdoor mounting tape to adhere the unit to the car so it isn't loose behind the trunk liner. You'll see what I'm talking about when you get into it.
Old Mar 15, 2017 | 10:31 AM
  #2331
Epiphany's Avatar
Epiphany
They're so easy to do that you'll only have time for a few sips while working on them. So easy and yet such a nice change from them.
Old Mar 15, 2017 | 10:39 AM
  #2332
QuinnDEskimo's Avatar
QuinnDEskimo
This is a great tip. I may just have to open mine back up to apply a little tape to them.
Old Mar 15, 2017 | 11:11 AM
  #2333
Nico-derm's Avatar
Nico-derm
Thanks John, I'll have a roll on hand.
Originally Posted by Epiphany
.. you'll only have time for a few sips while working on them....
You may be underestimating my love for beer.... I may have one per side!
Old Mar 15, 2017 | 12:19 PM
  #2334
woofersus's Avatar
woofersus
They look a little thicker to me as well, but I had a distant hope that somebody might know that those various silicone tube products are basically all the same thickness, or some such thing. I suppose I'll just order a couple different sizes and see what works.
I guess it's possible that leaving off the clamps is still bad, but they really are quite snug, and without the accordion segments there's certainly no way for the tube to move around or come off. Despite the simple mechanics and easy access of the job, it turned out to be a fair PITA to get them on the car with the need to significantly deform the tubes and then wiggle them back and forth onto the throttle bodies.
Old Mar 16, 2017 | 06:51 PM
  #2335
Saltman's Avatar
Saltman
Finally blacked out the trim thanks to the handy DIY instructions from Blnewt.
Before...
After....
now I just need to do the rear valance. Any suggestions to make it easier?
Old Mar 16, 2017 | 06:57 PM
  #2336
the93owner's Avatar
the93owner
Looks great! Goes very well with the blacked out coupe 19s.
I, on the other hand, installed my Carsmo ***** today. They should have come like this from the factory!
Old Mar 16, 2017 | 11:18 PM
  #2337
Looks like you did a great job, really completes the overall look
As far as the valance area. I did mine in Carbon wrap, and what I did was~
use a piece of celophane plastic wrap (just laid down, not stretched at all) on half the valance (be sure to measure an accurate halfway point), I then used a sharpie and made dots every inch or so to outline the outside perimeter including about 3" under the bumper. You then lay this onto your vinyl and do that half, flip the half over onto the rest of the vinyl to get cut an identical opposing half, You might want to cut just a hair over what you "sharpied" then you can do a final exact cut, better to have a bit more than not enough prior to final fit.
You will need to drop your muffler cans to get up into the exhaust cutouts. Here's a couple pics of mine for reference, been on for four years and still looks as day one~
Old Mar 16, 2017 | 11:24 PM
  #2338
iCrap's Avatar
iCrap
^ I did mine without dropping the mufflers. I ended up not liking the wrap look on blue slate... peeled it off not long after.
Old Mar 16, 2017 | 11:34 PM
  #2339
Saltman's Avatar
Saltman
Thanks! I agree the ***** should've come like that from factory. Adds so much more class with that simple upgrade.
You are DA MAN! I never would have thought of that. It's gonna make it so much easier. Thanks!
Old Mar 17, 2017 | 02:10 AM
  #2340
R1cky's Avatar
R1cky
