Fob range increase.Has anyone tried this?
Old Mar 29, 2016 | 09:40 AM
gman69's Avatar
gman69
I just watched this video that said if you put two CR2016 CV batteries in your fob creating 6 volts instead of 3 volts it will give you longer range to lock and unlock your doors. Not sure if it will work or not. I sure don't want to damage my fob.Thoughts???
Old Mar 29, 2016 | 10:29 AM
Mr.Grant's Avatar
Mr.Grant
I just put the key fob up to my head and look in the direction of my car. lol
I also doubt that will work because I don't think the keyfob could fit two batteries.
Old Mar 29, 2016 | 10:30 AM
ChinkyChoy's Avatar
ChinkyChoy
put mine under my chin lol
Old Mar 29, 2016 | 10:33 AM
IracknBack's Avatar
IracknBack
I have for real tested the under chin thing and it added ~20ft of range! HAHA.
As for wiring 2 batts in series to double the volts? I don't see the value added but I would very much do it in parallel to double the time between battery changes. YMMV
Old Mar 29, 2016 | 10:34 AM
qmantran's Avatar
qmantran
I also just place it under my chin
Old Mar 29, 2016 | 10:49 AM
Splitpi's Avatar
Splitpi
While I would guess that the circuitry could handle the extra voltage and not fry anything, I would not recommend it as your gain would be marginal.
Old Mar 29, 2016 | 10:50 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
not sure why i would need to unlock my door farther away than when im standing next ot it.. i always use the button on the door
Old Mar 29, 2016 | 11:03 AM
gman69's Avatar
gman69
Yes the chin thing works. I have the auto start feature installed on my car using the oem fob. I just want extra range when starting it from a distance. I have the Viper alarm on my Mustang but I didn't want an extra fob on my Infiniti.
Old Mar 29, 2016 | 11:07 AM
gman69's Avatar
gman69
These batteries are thinner and are supposed to fit.
Old Mar 29, 2016 | 11:18 AM
ANMVQ's Avatar
ANMVQ
only time I use the fob and not next to the car is to roll the windows down, Summer time. So the car is not boiling inside when I get in, I also use the head/chin trick
Old Mar 29, 2016 | 12:02 PM
gman69's Avatar
gman69
Lol.... Yeah I want the range to start my car when it's hot outside I can get the A/C going or when it's cold I can get the heater going.
Old Mar 29, 2016 | 01:01 PM
ToXIc's Avatar
ToXIc
i just do the chin mod
Old Mar 29, 2016 | 04:06 PM
Mr Nurner's Avatar
Mr Nurner
You could also add a Fortin Evo and third party long range remotes. I'm looking to do this soon to my existing fortin Evo module that I use for remote start with the oem fobs.
See Fortin | Bypass modules, remote starters and alarm systems for more info
Old Mar 29, 2016 | 04:38 PM
slartibartfast's Avatar
slartibartfast
Me too. I just worry the button cover will eventually decompose.
Old Mar 29, 2016 | 04:59 PM
guy from norcal's Avatar
guy from norcal
thats some 90's old school right there!!
