Whistle/high pitch sound from engine @ WOT
Old Jan 25, 2016 | 06:07 PM
4DRZ's Avatar
4DRZ
Jsolo- It could be ice cold trans fluid. I only notice it under extreme cold when first driving. Fortunately, the engine puts out so much heat that it does not last very long
Old Feb 18, 2016 | 11:52 PM
Victory's Avatar
Victory
is it this noise?
https://www.myg37.com/forums/g37-sed...-sound-is.html
Dealership checked the belts and for intake and exhaust leaks. Nada. others have had similar noises. Best guess so far is A whistle from the airbox or benign VVEL noises.
Old Feb 19, 2016 | 12:32 AM
Victory's Avatar
Victory
Originally Posted by conquistador
Check to see if the intake resonators were removed. They are the empty plastic, funny-shaped boxes sticking out the bottom of the filter housing and on the two intake hoses/tubes. Mine starting doing the whistling after I put MAF tubes and drop in Afe filters. I also removed the resonators from the housing.
My '13 sedan doesn't have the the airbox resonators and they don't appear to have been removed. The hole in the side of the box is has a plug in it that appears to be original equipment. Possible they removed the resonators in later years?
Edit: Parts lookup shows it was done away with in MY2011.
