Key Fob Battery
Old Jan 18, 2016 | 06:00 PM
  #31
4DRZ's Avatar
4DRZ
Originally Posted by greco65
Be as carefully as possible. I had to replace the battery on my G35 and i broke the little "hooks". On my G37 I almost attack it as a surgery very very carefully.
About how long the batteries lasts I had to replace mine on the G37 with the couple years while on my G35 it took almost 8 years before I replace them. I guess all the electronics on the G37 they drain the battery faster than on the G35, I guess.
The battery in the G37 with intelligent key will drain much faster as it is constantly sending out a signal to the car. (Similar to holding down the button on the remote 24/7) The battery in the G35 was probably a regular remote which only used the battery when you hit the button.
Old Apr 3, 2016 | 03:36 AM
  #32
UCLAG37's Avatar
UCLAG37
Originally Posted by omahawk
I changed my fob battery this past weekend and every third to fourth start the low battery warning will still come back. Is there a reset that I may have missed?
I had the same problem even with a new battery. The low battery light wouldn't go away so I decided to try something random and it worked! The light went away and hasn't come back.
I got in the car and pressed the start button twice (without my foot on the brake pedal) to get to the mode where all the lights show up on the instrument cluster including the low battery light. While in that mode and while in the car, I took apart the key fob and took out the battery and re-installed the same battery. The low battery light went away and hasn't come back. This seemed to have a resetting type effect. It worked for me, hope this works for others.
UCLAg37
ttiller
Jan 5, 2023 09:03 PM
ug2215
General Tech Questions
Jan 1, 2019 12:00 PM
chris_s
12
Feb 29, 2016 03:59 PM
sLADe781
Dec 4, 2015 09:19 AM
G Coop
Nov 29, 2015 01:26 AM
