New to me 2013 G37xs, impression so far
Old Dec 2, 2015 | 01:09 PM
AUR11's Avatar
AUR11
^^this
Ever notice nobody complains about throttle lag in the 6MT
I have my days where I hope someone totals out my car so I can get a 6MT sedan. I would just ask they not mess up my wheels lol.
Old Dec 2, 2015 | 01:14 PM
Ricio1991's Avatar
Ricio1991
Yeah sometimes I feel like there no acceleration with this 7 speed and can cause me to get in accident if I need to accelerate quick enough due to it lagging so much :-(
Old Dec 2, 2015 | 01:33 PM
Alcaponed's Avatar
Alcaponed
As many others have said, you bought the wrong package. The coupe xS is fine, but the sedan is just an x with the Sport appearance really. The S is epic even in automatic form, and it can keep up with Miatas, 370Zs, you name it. I take it canyon running all the time and the handling is bar-none. I have yet to drive a car I love as much as this thing. If you have to have AWD, get the coupe, because the S sedan is leaps and bounds better than the xS.
Old Dec 2, 2015 | 01:45 PM
Regardless of package, all stock G's understeer in a big way. It's very frustrating, and very easy to fix. I suspect that if the OP installed a set of aftermarket swaybars, he'll do a 180 on his opinions.
Old Dec 2, 2015 | 02:06 PM
GeezerB's Avatar
GeezerB
You owe it to yourself to drive a RWD S model before finalizing your opinion. The steering ratio is much quicker, paddle shifters, sport seat, stiffer suspension & other upgrades. Mine flies around corners. You might try clearing your ECU as it slowly transitions to grandma mode if you don't drive aggressively.
An XS is really not a "S".
Old Dec 2, 2015 | 02:14 PM
Lego_Maniac's Avatar
Lego_Maniac
Meh, the xS coupe still lacks the faster ratio steering, sport dampers and summer tires. They're both sport packages in name only.
Old Dec 2, 2015 | 02:16 PM
Meh, the xS coupe still lacks the faster ratio steering...
So true, Lego. That particular feature doesn't get much attention, but it's actually huge. Makes a tremendous difference.
Old Dec 2, 2015 | 06:23 PM
4DOORFUN's Avatar
4DOORFUN
I know you already heard this, but you should have bought have the RWD S and used winter wheels/tires in the cold weather months. Infinti, like many of its competitors, took a RWD platform and softened it by offering AWD to sell more cars. The G was designed to be RWD and the VQ motor is perfectly matched with a 6MT.
Old Dec 2, 2015 | 06:54 PM
If you haven't done it yet OP, turn off the VDC button for a little more pop. Just be sure to try it out where no harm can be done the first time out.
Old Dec 2, 2015 | 07:13 PM
JSolo's Avatar
JSolo
Just say no!!!!!
If the OP found the XS sedan to be rough handling, the rwd S sedan would be stiffer yet. As for steering, IIRC, the XS _coupe_ does have the true sporty bits of the rwd S coupe or sedan, including the vlsd, sport suspension, bbk, and tighter steering.
Look at the attchment, under the g37x coupe, page 5, sport package.
Recalling test drive of the XS sedan (never drove a true xs coupe), we barely got 2 blocks away from the dealer before returning. The car felt like a sponge with wheels. Lacked the responsive handling I was looking for. The car was to be a replacement for a sportbike-- sort of. I was used to stiff/rough rides. The rwd S sedan while stiff, doesn't seem all that harsh and will well controlled.
Old Dec 2, 2015 | 08:00 PM
RavensMinded00's Avatar
RavensMinded00
As an X owner myself, I had very similiar feelings first coming to the car. Had loads of straight line uhmp but was uninspiring around the twisties. First things I did was new break kit and as others have mentioned, lower sway bars. By far the most bang for the buck mod you can do with the G, especially the X model due to its tenancies to under steer and has a good amount of body roll. Do yourself a favor, buy the Sways and get back to us, I'm sure your opinion will change dramatically.
Old Dec 2, 2015 | 08:24 PM
Lego_Maniac
This has been discussed in detail in other threads. Infiniti marketing materials seem to imply the the xS coupe gets the faster ratio steering, but they don't. Same with the Sport suspension. The coupes do get the BBK kit though.
Old Dec 2, 2015 | 10:12 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Are you saying the information provided in the pdf is wrong?
What about the info at this link:
2015 Infiniti Q60 Coupe Specs | Infiniti USA
Under Packages for the awd model +$1950
  • 19 x 8.5-inch (front) and 19 x 9.0-inch (rear), split V-spoke aluminum-alloy wheels with 225/45R19 (front) and 245/40R19 (rear) W-rated summer performance tires
  • Sport-tuned suspension with upgraded springs and double piston shock absorbers
  • Viscous Limited-Slip Differential (VLSD)
  • Sport brakes
  • Sport front fascia
  • Solid magnesium paddle shifters
  • 14.7:1 sport-tuned steering gear
  • 12-way power driver's sport seat
  • Aluminum pedal accents
Old Dec 2, 2015 | 10:18 PM
  #29
Michael440's Avatar
Michael440
Do the newest software update to your tranny. it should fix that problem
Old Dec 2, 2015 | 10:19 PM
  #30
MaQG37's Avatar
MaQG37
^ I don't think they had a VLSD either..
