First Dealer experience
Old Nov 14, 2015 | 01:42 PM
Epiphany's Avatar
Epiphany
Originally Posted by greco65
Most of these items are covered in the warranty. But the battery at least they changed because if it was really low and you had to replace it, then you had to reprogram both FOB so this will set you back at least $75.
I haven't seen anything about this before, why does the FOB need reprogramming?
Old Nov 14, 2015 | 02:04 PM
socketz67's Avatar
socketz67
Community Builder
I had to replace my FOB battery around the two year mark. Standard CR2032 coin cell.
If I recall, there was a warning light on the dash which indicated the battery was low. It flashes for a few seconds, then goes off. At some point, if the battery is completely drained, there is another indicator which tells you to put it into the intelligent key holder, which is to the left of the steering wheel near your knee.
I don't use my key to set the seat position (I leave it in the same position and am the only one that drives my car), so I never had to perform this process:
Actually, I'm not sure now if this has anything to do with the seat. When I replaced the battery, this step was not necessary.
I think the programming is needed when you buy a new one. It will then need a value flashed into it's NVRAM that is the id for your specific car.
Hopefully this will save you $75 that you can spend on something more interesting, like a roof spoiler
DennisG37
Feb 25, 2016 01:49 PM
GW330
Oct 16, 2015 02:29 PM
sukhusukhu
Oct 15, 2015 03:56 PM
Digilog
Motorsports / Track
Oct 15, 2015 12:23 PM
Detailed Image
Lighting/Cleaning Products
Oct 14, 2015 12:53 PM
