True reason the sport package sedan did not come with the Akebono BBK?
Was it strictly and completely a cost saving measure? Was there any other reasoning behind this decision by Infiniti?
I know the awd also comes with a much thinner rear sway bar, which enthusiasts are upset about, but I read it was a safety measure as it helps prevent oversteer in snow conditions, and that was the reasoning Infiniti put the thinner rear sway bar in the awd G37. Is there anything like this, that has been talked about for the lack of the Akebono bbk being included on the sedan awd Or was it strictly a cost saving measure by Infiniti?
I suspect cost. But that doesn't explain why they didn't offer it as an upgrade option. Good point on the sways and oversteer, but it doesn't explain why the front sways are weak, too.
As Brad just said, only someone on the inside can truly answer that question. I think when it comes to decisions on car production, there are cost factors that can only be explained end-to-end, because all by themselves it doesn't make any sense.
Looking at your posts, it seems you've been doing research on a used G37xS. Should you buy one, and if you only do one mod to that car ever, make it a pair of aftermarket swaybars.
I'd imagine infiniti's market research showed that AWD buyers wouldn't want to pay the incremental cost fir the RWD S hardware.
The x doest get the faster ratio steering, summer tires or stiffer shocks either.
BMW x-drive offerings at the time were the same in that they didn't get the suspension upgrades of the RWD.
Rochester you mentioned the front sways are weak? I thought the front sways were the same on the XS as the S coupe? I have one from the coupe and the thickness is the same so I didn't bother installing it?
Actually the stopping power is pretty similar (at least w/ the OEM pads), where the Akebonos shine is in prolonged use like tracking where the regular brakes overheat and will fade, the Akebonos will stay cooler and perform better.
I ask as I read somewhere how well the awd performs and it does not take a lot away from the regular rwd, the only place it does takes away is the additional stopping distance and they thought the reason for that was the sport package comes with bigger brakes.
The sport brakes are going to really shine in repeated use. An emergency stop? Probably doesn't matter. 15 70-0 stops? The sport brakes will fade less and stop shorter.
Tires probably play a bigger role than brakes in emergency stopping distances.
The stiffer opposed piston calipers will also flex less, and should provide better pedal feel. And there is an abundance of aftermarket pad options since the brakes are shared with the 370Z.
The stopping distance is probably the closest between the AWD and RWD. It's handling that the RWD, particularly in S configuration, is going to be way ahead of the AWD in.
But man do they look good.
First thing to do if you want to decrease your stopping distance, you need to get "sticker" tires. Think about it, you can have the best brakes in the world, but if your on very hard rubber you will take longer to stop than a softer tire. This reminds me of the MCM video with the FRS and BRZ or maybe they both were the same idr.
different part, but basically same concept.
Last edited by Jonesmeister11; Oct 9, 2015 at 10:03 PM. Reason: Decided to look for the video
