View Poll Results: Is a RWD dangerous on the snow?
No
32.61%
Depends on how you drive (so: no unless you're stupid)
23
50.00%
Yes
17.39%
Voters: 46. You may not vote on this poll
What do you think? G37s in the snow?
Old Sep 15, 2015 | 07:10 PM
Originally Posted by Laguna
Thank you guys!
Quick question, everybody talks about "good technique". Is there a magic technique on snow or just common sense? "don't go fast if there's snow" and that's it? If so, i wasn't thinking on racing in the middle of winter ^_^
Thanks again!
If you're at a dead stop, and have no forward traction, don't gun it hoping to burn your way to pavement. You need to rock the car back and forth a number of times so that you're momentum pushes you out of the dead spot.
Other than that, go into turns with proper caution. And if your TC light starts flashing at you, perhaps you're using too much throttle.
G'luck.
Old Sep 15, 2015 | 07:37 PM
Victory's Avatar
Victory
Originally Posted by Selym
It's correct. By adding weight to the trunk, you're shifting the center of mass rearward. How much harder to control is the question.
Insignificant. You will get a little more traction to start and some grit if you get stuck.
Old Sep 15, 2015 | 07:55 PM
Upscale Speed's Avatar
Upscale Speed
Buy a 6-8k SUV or truck for the winter and keep the G in good shape. Winters are rough on cars and the G is too nice a car IMO to drive in the winter. I'm putting mine away for the winter and doing exactly that in the next week or two. If you do park it for the winter make sure to put it on blocks and take off the serpentine belt. Also put some stabil in the fuel tank.
Old Sep 15, 2015 | 08:10 PM
Laguna's Avatar
Laguna
I don't think I'll have 2 parking spots, but it's an option!
Why would you put it on blocks and take off the serpentine belt? (not saying no, just want to understand )
And also, that happens when you drive in the winter? what does it do to the car?
thanks again
Old Sep 15, 2015 | 08:14 PM
the_wolff's Avatar
the_wolff
G'luck.
I'd add to slow down before turns. No braking (if you can help it) while turning. Also, if/when you start to slide, feet off the brake and steer through it. Skid control is a skill of its own, there are plenty of youtube videos on technique.
Old Sep 15, 2015 | 08:16 PM
Selym's Avatar
Selym
thanks again
The salt that is used to de-ice the roads along with the moisture from the melting snow and ice create a highly corrosive environment.
Also, the sand that's laid down to provide traction gets kicked up and sandblasts your paint.
I wish I had room for a winter beater.
Old Sep 15, 2015 | 08:18 PM
Selym's Avatar
Selym
Thank you guys!
Thanks again!
Find an empty parking lot and see how the car handles in slippery conditions.
Old Sep 15, 2015 | 08:20 PM
PG-v36_6MT's Avatar
PG-v36_6MT
RWD in the snow? No problem
Oh, and if you're worried about your beautiful G getting dirty in the winter, what do you think car washes are for?
Old Sep 15, 2015 | 09:25 PM
the_wolff's Avatar
the_wolff
I'm not going to lie, this one made me cringe. Glad to see her all cleaned up afterward. Cheers!
Old Sep 16, 2015 | 12:31 AM
Victory's Avatar
Victory
Maybe a bit off topic, but for harsh, salty winters, nothing beats Collinite Insulator Wax. Stuff is designed for nasty conditions and salt spray.
Old Sep 16, 2015 | 08:11 AM
RichardMiami's Avatar
RichardMiami
What is this "snow" thing you are talking about?????
Old Sep 16, 2015 | 01:02 PM
Laguna's Avatar
Laguna
I don't really know, I live in North California and we've heard of weird things like "snow" and "rain". I guess those are mythical things some people talk about...
In any case "snow" is something that falls down in the Chicago area AFAIK
Old Sep 16, 2015 | 07:40 PM
Upscale Speed
thanks again
Put it on blocks to avoid the tires getting flat spots in them, take the serpentine belt off to avoid getting flat spots on the pulley bearings (Alt, crank, A/C, idlers, etc.). Use Stabil to prevent moisture.
Regarding driving it in the winter you certainly can do that as long as you are careful. RWD you can too you just have to be more careful. I'm all set down that in my G. I did it last year and it is mediocre in the snow IMO. I live in Maine and we got over 100" of snow last year so that helped me make my decision. Also I want it to stay in puff condition and driving in the snow will not do anything but bad for your chassis (salt and moisture do not mix). Yes they have car washes, but that won't help you 100%.
Old Sep 16, 2015 | 09:00 PM
  #29
claudiohv's Avatar
claudiohv
Thank you guys!
Thanks again!
If you are stuck turn off VDC, otherwise your break (back) will melt. That's 1 thing I know
Old Sep 16, 2015 | 09:11 PM
  #30
That's a great point. TC will keep you straight-ish and safe. But if you're stuck and need to muscle the car around with some finesse, you have to turn TC off.
