Thinking about Seafoam
Old May 10, 2015 | 10:59 AM
RickyDgmZ's Avatar
RickyDgmZ
How exactly does it do this?
The liquid is not a fuel. Which throws the ratio of A:F off. Which can cause the car to run lean and foul out the plugs. Of course if you let it trickle into the vehicle at a steady stream you'll more than likely be okay. I've seen people use a very generous amount of a seafoam type cleaner on their vehicles and it causes it to bog out and die. Also it may or may not throw a check engine light to cause random misfires. It's just what I've seen from people doing it. I'm sure there are benefits to using it. I would personally stay away from the product as far as that goes.
User 122320
Sep 17, 2015 02:28 PM
si_driver
Sep 13, 2015 12:04 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
inspector94
Sep 8, 2015 12:57 PM
