G37xs sedans - lowered with rim
Old Mar 26, 2015 | 07:37 AM
ILUCKYI's Avatar
ILUCKYI
Hi can you guys with g37xs AWD sedans (2010+) please post some pictures of your cars letting me know what suspension and what size rims you have. I'm trying to get ideas. Thanks
Old Mar 26, 2015 | 07:56 AM
eurtsx's Avatar
eurtsx
2010 G37xS
BC Coilovers
19x9.5 +43 Nismo Rays (Squared Set)
Old Mar 26, 2015 | 11:22 AM
ILUCKYI's Avatar
ILUCKYI
Originally Posted by eurtsx
2010 G37xS
BC Coilovers
Looks nice. Are those bc's made specifically for the XS AWD sedan? How do they ride? I'm guessing u needed a camber kit right?
Old Mar 26, 2015 | 11:38 AM
tbulsara's Avatar
tbulsara
Both my setups are square.
20x10.5
lowered on D2 Racing Coils. with dampening set on the middle setting.
The first pic (older setup)
Stance SC5 +35 offset all around 275/30/20
The Second (Newer Setup)
Avant Garde M310 +25
Attached Thumbnails G37xs sedans - lowered with rim-screen-shot-2015-03-26-at-11.35.45-am.jpg   G37xs sedans - lowered with rim-screen-shot-2015-03-26-at-11.35.23-am.jpg
Old Mar 26, 2015 | 02:55 PM
ILUCKYI's Avatar
ILUCKYI
Do AWD need to have a squared set of rims? I've heard on one of the threads on here that you can't run staggered on AWD because the tires will overheat or something? That true?
Old Mar 26, 2015 | 02:59 PM
Baby Jumpman's Avatar
Baby Jumpman
Eibach springs with 20mm spacers all around. Coupe 19x9 square setup with 245/40 tires.
Old Mar 26, 2015 | 03:01 PM
tbulsara's Avatar
tbulsara
you can run staggered, as long as the rolling diameter of the tires is the same front and back otherwise your AWD will F*#@ up...
Old Mar 26, 2015 | 03:07 PM
Baby Jumpman
Tbulsara you running the same size tire for the second setup?
And lucky that's not true you just have to be careful with tire sizes and rolling diameters.
Old Mar 26, 2015 | 03:10 PM
tbulsara's Avatar
tbulsara
yes, both my setups run 275/30/20 all around.
my very first setup on my car was staggered.
Old Mar 26, 2015 | 03:29 PM
Sobbie84's Avatar
Sobbie84
love the whip and them rims bro... With them 20's lowered is there any rubbing when it comes to fenders?. i am trying to put 20s on my 2011 g37x sedan
Old Mar 26, 2015 | 03:49 PM
Baby Jumpman
Thanks for the quick reply my next setup will be 19x10.5 all around. My shoot for 265/30 though. I'm fine with some camber and I know I'll have to pull the front fender.
Old Mar 26, 2015 | 04:07 PM
tbulsara's Avatar
tbulsara
when i had +35, i had to pull the front fenders,
After going with the +25, i had to get the rear pulled as well.
but then again i am running 275/30/20. if i ran 255, i could get away without pulling the rear fenders but the tire would have a great deal of stretch.
Old Mar 26, 2015 | 04:22 PM
Baby Jumpman
Hmm I'm gunna be running either+20 or +25 all around so that's good to know. I've read about the tears being rolled/pulled from the factory so I'd be abLE to trim the fender bracket and liner but if I can roll it more I'd do that.
Old Mar 26, 2015 | 04:24 PM
tbulsara's Avatar
tbulsara
+20 is a coupe setup,... for sedans that is very aggressive. unless you want to drive with a lot of negative camber, i would not recommend +20.
My current setup were +20 and i had them shaved to +25 as when installed as +20, it was too aggressive.
Old Mar 26, 2015 | 05:47 PM
Baby Jumpman
The only thing is the wheels I like are +20, but another style from the same company is +25 so I might go with that for a little easier fit. I only considered +20 after doing the math and seeing that it'll only stick out half an inch further than my current setup.
G's
Nov 5, 2023 12:01 PM
Mattlorentzoe
May 24, 2021 08:49 PM
drewfinity
Aug 20, 2015 08:17 PM
zzww1251
Aug 8, 2015 06:19 PM
