How would you secure a toolbox in the trunk?
Old Feb 16, 2015 | 07:44 PM
  #31
G37Xtreme's Avatar
G37Xtreme
Originally Posted by forrmark
A tool box should be heavy enough so that it would not move around much in the trunk.
This doesn't fit at all with reality. My toolbox has been to every corner of my trunk, and tipped over as well.
Old Feb 16, 2015 | 09:21 PM
  #32
The thought of a heavy toolbox slamming into the fenders from the inside... yikes!
Old Feb 17, 2015 | 02:25 PM
  #33
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
if you want to keep a toolbox in your trunk then buy a truck
Old Feb 17, 2015 | 09:55 PM
  #34
G37Xtreme's Avatar
G37Xtreme
You're right. I just traded in my G37 and bought a Silverado 2500 so I could carry jumper cables, tire repair kit, 12V air compressor, and some screwdrivers in my trunk.
Old Feb 18, 2015 | 11:48 AM
  #35
tbear's Avatar
tbear
Try this
1) Get a WeatherTech trunk liner. It has a high friction surface that I find greatly reduces objects sliding around
2) Get a tool bag like the DeWalt DG5511. It is very study and rigid, has grippers on the bottom, pockets galore, holds a lot and if it flips or slides will be less likely to damage your fender. It has a zipper on top, and allows you to load the heavy tools at the bottom to keep the center of gravity low. Keeping the weight low is very important to avoid flipping or tipping.
3) Put the tool bag long side against the back of the rear seat and in a corner as the highest force will likely be from emergency braking.
I don't often carry tools this way, but when i do, they stay put. I keep all kinds of stuff in my trunk in the winter for emergencies including a very heavy (about 25 pounds) Schumacher proseries 2212 jump starter pack. It is in a stiff fabric trunk box with grippy feet and it never slides around.
Old Feb 18, 2015 | 12:05 PM
  #36
Daddy Fat Sacs
well all of that stuff can fit in the cargo net and not really move around pending size of the compressor.
Old Feb 18, 2015 | 12:29 PM
  #37
Bears04r1's Avatar
Bears04r1
I have a small Craftsman set that sits flat, and a small Eddy Bauer car tool kit in a small fabric bag that sits on top.
I got some nylon straps with velcro (from Home Depot) and cut some slits into the trunk liner and ran them through that so everything can sit nicely tucked away in the left corner. The strap velcros around the handle on the bag.
Old Feb 18, 2015 | 02:43 PM
  #38
G37Xtreme's Avatar
G37Xtreme
But then, I don't have an empty cargo net to use.
I've got velcro on order from Amazon. I should have it tomorrow. Then we'll see if my idea works.
Old Feb 19, 2015 | 02:14 PM
  #39
guy from norcal's Avatar
guy from norcal
I have a tool bag that doesn't slide around. even if you don't have the cargo net,it still should have the loop clips so you can use a bungee cord.
Old Feb 20, 2015 | 08:37 AM
  #40
Daddy Fat Sacs
I just think you want to build something cool in the trunk is all
Old Feb 20, 2015 | 01:00 PM
  #41
BeachmanQ60's Avatar
BeachmanQ60
I use road side assistance app in my smart phone......nothing slides around or tips over...
Old Feb 20, 2015 | 01:40 PM
  #42
G37Xtreme's Avatar
G37Xtreme
How do you secure the smartphone in your trunk?
Old Feb 20, 2015 | 04:51 PM
  #43
guy from norcal
Old Feb 20, 2015 | 09:59 PM
  #44
speedracer g37's Avatar
speedracer g37
i have an ammo case like this full of car care stuff. it fits snug under the parcel ledge and the floor of the trunk, snug enough that it won't slide around while i drive. got mine at walmart, in the sporting goods section,
Amazon.com: MTM 50 Caliber Ammo Can: Sports & Outdoors Amazon.com: MTM 50 Caliber Ammo Can: Sports & Outdoors
Amazon.com : 1612 Plano Deep Field Box : Fishing Tackle Boxes : Sports & Outdoors Amazon.com : 1612 Plano Deep Field Box : Fishing Tackle Boxes : Sports & Outdoors
Old Feb 21, 2015 | 08:43 AM
  #45
G37Xtreme's Avatar
G37Xtreme
It seems that Velcro doesn't stick to the floor of the trunk. I have tried it on both the standard floor, and the floor-mat like pad in the trunk.
Velcro does however stick to the walls of the trunk pretty well. I am in the process of redesigning these straps and the location of the toolbox.
