How would you secure a toolbox in the trunk?
Old Feb 12, 2015 | 09:49 AM
I keep a torque wrench and a 21mm socket in my car for the first 500 miles after a wheel is taken off and replaced.
Gotta respect that.
I double-check the lug-nuts at least once after putting a wheel on and driving around for a day or two. Sometimes twice.
Here's another tip that might seem obvious, but until you think of it the first time, it might not get thunk: if you have aftermarket wheels, you still need to keep a set of five OEM lug nuts in the car, for the spare.
Old Feb 12, 2015 | 10:42 AM
Lego_Maniac's Avatar
Lego_Maniac
For the wheels.
And how often do you bust out the torque wrench to check the lugs away from home
And I thought I was obsessive compulsive
Old Feb 12, 2015 | 11:47 AM
alxmlr789's Avatar
alxmlr789
Gotta respect that.
Couldn't agree more with this. Nothing would be worse than to not have what you need to simply change a flat.
Old Feb 12, 2015 | 12:17 PM
So far, never. But you never know.
Jokes aside, the torque wrench is simply much easier to use than the OEM crowbar thingy.
Old Feb 12, 2015 | 12:18 PM
TheLocNar's Avatar
TheLocNar
I just use a duffel bag.
Old Feb 12, 2015 | 12:21 PM
G37Xtreme's Avatar
G37Xtreme
Joke-Mode enabled
Maybe I'll start putting my air compressor in the trunk and keeping my impact wrench with me. I'll need a 15 amp inverter
Old Feb 12, 2015 | 02:13 PM
guy from norcal's Avatar
guy from norcal
I have a cardboard box
Old Feb 12, 2015 | 02:40 PM
Lego_Maniac
Perhaps, but you'll still need the crowbar thingy to remove the lugs. It's not a good idea to use a torque wrench to loosen bolts, but you probably already know that.
I prefer a 1/2" drive flex head ratchet to loosen the lugs.
Old Feb 12, 2015 | 06:07 PM
What, for fear of damaging the torque wrench? Nah.
I up the wrench to 100 for easy removal, then down to 85 when torquing the lug nuts back down. Been doing that for decades now.
Lego, if you know something I don't and should, by all means go ahead and say your peace.
Old Feb 13, 2015 | 06:38 AM
Lego_Maniac
I was always told, and the instructions said, not to loosen bolts with a torque wrench.
If you google 'torque wrench to loosen bolts' virtually everything is going to advise against it. Tools are designed for a specific purpose, and loosening bolts isn't it what a torque wrench is for.
Torque Wrench Myths - Circle Track Magazine
A Torque Wrench Should Never be Used to Loosen Fasteners
This one is the truth. You might argue that if a torque wrench can handle tightening bolts to 250 ft-lbs, it should be able to reliably handle loosening that same bolt. And this is true, but when it comes to loosening a fastener you don’t always know what’s going to be required to get it loose.
After several heat cycles and the accumulation of dirt and grime that can coat everything in a race car, a bolt can gall against the threads and require a lot more torque to remove than was required to originally install. Most of us don’t watch the torque when loosening bolts, so it’s quite possible to exceed the maximum torque loading of a wrench when breaking bolts loose. The wrench will still function in terms of tightening or loosening bolts, but by exceeding its maximum torque limit loosening that tight bolt may have thrown off the calibration.
But if you've been doing it for decades, then your anecdotal experience is just as valid a data point as forums or hot rod magazine. Maybe I'm over thinking it.
My torque wrench is probably my single most expensive hand tool. I don't use it to loosen bolts, and I don't want it banging around in my trunk.
You're a little obsessive about lug nut torque. I'm a little obsessive about how I treat my torque wrench
Old Feb 13, 2015 | 08:34 AM
G37Xtreme's Avatar
G37Xtreme
The way this is written, it only seems like an issue if you have to use more torque than the wrench can handle. It's not specifically the fact that you're loosening, it's that you're loosening something that requires lots of torque.
Given the wording of the statement above, I wouldn't be too concerned to loosen a lug nut if it needs 90 ftlbs to come off, unless or course, your torque wrench stops at 89 ftlbs.
Old Feb 13, 2015 | 08:50 AM
Lego_Maniac
Like I said, I'm probably over thinking it. I have two 1/2" ratchets, a 1/2" breaker bar and a 1/2" sliding T handle. I just see no need to use my torque wrench to loosen bolts
I also store it set on the lowest torque setting.
Obviously all this only applies to click type wrenches.
Old Feb 13, 2015 | 08:58 AM
I do that, too. Although my current torque wrench is some $30 amazon purchase from like 10 years ago.
All this talk has got me thinking about buying a really nice one.
What do you think of those digital wrenches? Or is that just a gimmick?
Old Feb 13, 2015 | 09:06 AM
  #29
Lego_Maniac
Digital is probably fine, although I probably wouldn't want a $30 digital one
Old Feb 16, 2015 | 01:51 PM
  #30
forrmark's Avatar
forrmark
A tool box should be heavy enough so that it would not move around much in the trunk.
My torque wrench from Harbor was real cheap,but works just fine. I think I used it once in four years.
