The ground clearance issue is how the ARK catback hangs. the old design used to be a little lower so people with lower cars would scrape a little more. ARK has now redesigned that area and they fixed it so it doesn't hang as low.
I believe its lower around the mid section and flex pipe area
All, I've noticed a substantial decrease in the audible "hiss" coming from my exhaust after swapping out my FI RHFCs and replacing with Z1 HFCs. A bit lower tone and more "burble" is noticeable. Could be those two points "masking" the hiss but I don't notice it as much on deceleration after the equipment swap.
yaaaaaaaaaaas I love that burble sound cant wait to get my RHFC on
fak I misread but I still suspect that there will be more of a burble sounds with RHFC than OEM Cats
I can't imagine you would, actually. That resonator post-cat really destroys all the popping and burbling. My mechanic tends to agree as well. He noticed it immediately after I started up the car with the new cats.
I'm letting those suckers break in for a while and then depending on what kind of sound is developed, I may switch back to my unresonated X-pipe.
Are you saying the product has been updated to have more clearance? With this update, is it still lower than other, but by less? Also, when was the update, and how would one ensure that ordering one from a vendor would yield the newer spec?
The issue in the original design were the flex pipes before the X pipe, as CC did point out they are different now.
I'm not sure how much higher the flex pipes are in the new design, maybe ANMVQ can take a side profile shot of that section to show the ground clearance.
Original Version in the red box (using these old pics because this is all I have before the exhaust was molested by the streets of Houston):
