Car wouldn't start
Old Dec 7, 2014 | 04:53 PM
telcoman's Avatar
telcoman
Originally Posted by Twista
Not yet. I thought that the car would let me know when the battery is low. The car still recognized the key as I was able to lock and unlock it with the fob as well as sound the panic button
Mine does!
A day after I read your post this popped up on my dash
Stopped by a nearby Batteries Plus. They measured the voltage on the original 3v battery and it read 2.8v
I had them them replace batteries in both key fobs which are now 2 1/2 years old
No more problem
Telcoman
Old Dec 8, 2014 | 01:05 AM
RA081224's Avatar
RA081224
Hmmm well it did it again today. This time it turned over once stopped waited 3 seconds and started up again. I had the door close so I don't know if it sparked or not. I checked the battery connections, all the connections on my big 3 upgrade, and checked the starter bolts and everything seems tight. Freakin starter is in a impossible place on these cars lol. Anything else U guys know of that I should check. I know there's a loose connection somewhere on this car.
If your 2011 is similar to the 2008 then there will be a small port just above the hood release latch that will allow you to insert your dead key fob into it and start the car. This should allow you to start the car no matter what the condition of the key fob battery.
Old Dec 8, 2014 | 01:06 AM
RA081224's Avatar
RA081224
Originally Posted by vqsmile
Hmm, if only there was some kind of reference manual specifically made for the car with explicit instructions on how to use and interpret all the myriad of functions that are built into such a marvelous machine.
Hmmm... if only.
Originally Posted by telcoman
There is
I purchased the four volume paper FSM for my previous 06 G35
It is well over 1000 pages.
Everything you need to know as well as a factory Infiniti tech is in there along with extensive troubleshooting steps with flow charts.
You can search for it on line but the I found the paper version much easier to use as well as having the ability to place paper stickies on certain pages for quick reference
Telcoman
Stop it you guys, your killing me
Old May 8, 2022 | 10:40 PM
noquincy's Avatar
noquincy
Hi, My name is Jan and I'm new here but I have a question about my 2009 G37. I've never seen anything like this. I got home from the grocery store and pushed the trunk release button to open the trunk. My aim must have been off and I went below the trunk release and found a cubby hole. This afternoon I went to start my car and the no key detected light came on. My grandson was with me and he placed the key fob in the cubby hole and it fired right up. What is this mysterious cubby hole and why do I have to put the key fob in it to start my car. It's right under the truck release and has two yellow lights on it. Any help on this would be greatly appreciated. Thanks, Jan
Old May 9, 2022 | 09:05 AM
ILM-NC G37S's Avatar
ILM-NC G37S
From the OWNERS manual:
Likely the battery in your fob is dying/dead.
Old May 9, 2022 | 02:14 PM
noquincy's Avatar
noquincy
Smile Thank you
Thank you so much for the prompt replies. I will change the battery pronto. Thank you again!! Jan
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
G37xhibeet
Nov 15, 2016 09:29 AM
JoshB
Oct 15, 2015 03:08 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
Corvalis
Aug 6, 2015 04:36 PM
