Splash Guards Question
Old Nov 25, 2014 | 01:49 PM
Chonch1224's Avatar
Chonch1224
Hey guys I was looking into getting Splash Guards for my G sooner than later. My real question is do they actually serve a purpose or more just for the look?
I want to get them to install them before the winter reason I asked.
Thanks
Old Nov 25, 2014 | 03:53 PM
canucklehead's Avatar
canucklehead
mine have proved to be somewhat useful. in the past i would get wet leaves splattered on the rocker panel and lower rear bumper behind the rear wheel. after installing the splash guards i notice the leaves do not make it past the splash guard and get all caught up on the wheel well facing of the guard. it's easy enough to knock off the crud from this surface for a quick clean.
Old Nov 25, 2014 | 05:00 PM
GAWD's Avatar
GAWD
Extremely effective if there are freshly asphalted streets in your area. Might not be as noticeable on your black car but on my red G road tar stands out like a sore thumb. The rear seems to throw more on the body than the fronts, which I found ironic since the front wheels pivot. You'd think the front would be the main offender.
Old Nov 25, 2014 | 06:31 PM
inyquest's Avatar
inyquest
What kind did you get factory or aftermarket?
Did you install yourself?
Old Nov 26, 2014 | 10:38 AM
Chonch1224's Avatar
Chonch1224
Thanks for the head up guys, I will be getting factory and installing myself.
@canucklehead & @GAWD - I have the same question as inyquest, What kind did you get factory or aftermarket?
Old Nov 26, 2014 | 11:12 AM
inyquest's Avatar
inyquest
Take and post pix of the install please
Old Nov 26, 2014 | 11:21 AM
G37Xtreme's Avatar
G37Xtreme
Do you have to get these painted?
Old Nov 26, 2014 | 11:50 AM
GAWD's Avatar
GAWD
I'm not aware of any aftermarket that are made specifically for the G. With that I'd suspect most, if not all generic universal jobs would look tacky. There is a mix of form & function with the OEM ones.
I purchased a brand-new set of OEM splash guards from the same ebay seller who sold all the midnight grills for cheap. He has (had?) several brand-new sets of front & rear painted in factory SILVER. I painted them red and installed them. Instructions are included and it takes no time at all to install. Its a combination of screws (included) and double sided tape (also included and comes pre-installed). With a stubby Phillips screw driver, you are looking at a couple 2-3 minutes per corner. Fronts are easiest as you can simply turn the wheel sharp. If you are due for a tire rotation, then thats probably the best time to install these, with the wheels removed.
Here is a link to the ebay listing.
http://www.ebay.com/itm/111485839005?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
He has them for $25 or "make offer". I offered $19 but they declined, tried $21.50 and they accepted, so with $13.38 shipping I am out $35 plus a little red paint & my time. If your car is silver, then you are good. If you want to order from your dealer expect to pay much more, but they come pre-painted your OEM color. I didn't snap any pictures but its super simple, double sided tape and a coupe screws per corner, no curve ***** or measuring or thinking required. I put well over 100K miles on my previous G35X and never lost one, so they are quality. Good luck.
Old Nov 26, 2014 | 12:06 PM
canucklehead
i got OEM factory accessories. unless a guy is doing a body kit i can't see any reason to get anything else. they come color matched to whatever color your car is so no painting required.
the install is a very simple DIY. there is a DIY thread somewhere on here so search for that. no special tools are required, and total time is ~1-1.5hrs from start to finish. ans that's working carefully as i was.
Old Nov 26, 2014 | 12:32 PM
G37Xtreme's Avatar
G37Xtreme
LOL, I didn't even realize that I have them. They were on the car when I bought it. I even almost bought the ones linked above as they are already the color of my car. Glad I brought out this pic of my car before buying...
Old Nov 26, 2014 | 07:17 PM
TomsG37's Avatar
TomsG37
Thanks GAWD. $20 Offer was accepted.
Old Dec 1, 2014 | 04:12 PM
Chonch1224's Avatar
Chonch1224
F38E0 JK606 Infiniti G35 Sedan Mudguard Set New OEM F38E0JK606 | eBay
Awesome! Will be buying and installing, now to get factory black paint...
Old Dec 5, 2014 | 07:23 PM
Phong's Avatar
Phong
Thank you very much GAWD. $35 shipped (offered accepted $20) and painted liquid platinum is a steal.
peterso2
Mar 25, 2019 11:28 AM
JG_G37
Sep 19, 2015 09:07 PM
nbast
Sep 14, 2015 12:39 PM
gdaelemans
Sep 13, 2015 09:36 PM
User 122320
Sep 4, 2015 05:25 PM
