View Poll Results: Next mod
Short Tube Headers
15.00%
3.9 gears
65.00%
Bored 63mm TB
20.00%
Multiple Choice Poll. Voters: 20. You may not vote on this poll
What should my next mod be? *Poll*
Old Nov 16, 2014 | 11:20 PM
  #31
alfredo24pr's Avatar
alfredo24pr
Originally Posted by conkus805
Sorry to blow up your thread but that diff I spoke of is still for sale on eBay, it's from an 09 7at vert with lsd for 399$. It would be a direct swap, no need to swap flanges.
So you are saying that it is a direct swap and I wouldn't need to buy the 3.9 gears? Even easier than swapping the 3.6?
Old Nov 16, 2014 | 11:52 PM
  #32
G37Sam's Avatar
G37Sam
Don't waste your money on short tube headers.
Gears make a night and day difference at every rpm in every gear.
Old Nov 17, 2014 | 12:41 AM
  #33
alfredo24pr
Originally Posted by G37Sam
Don't waste your money on short tube headers. Gears make a night and day difference at every rpm in every gear.
I will listen to the forum and do the gears before the headers. Hopefully, I will be so satisfied with the gears that I will forget about the header mod.
  #34
Mik3G37S's Avatar
Mik3G37S
Originally Posted by alfredo24pr
You are 6 MT, so your final drive is 3.6.
7AT has 3.3 final drive.
A jump from 3.3 to 4.08 might be too much for the 7AT.
For 6MT, 3.6 to 4.08 is not too much.
Something more equivalent for the 7AT would be going from 3.3 to 3.916
Right, sorry I get it now, I have forgotten the obvious that there is an obvious difference in gears between 6MT and 7AT( which I don't really follow) but what I've been always hearing or reading about has been rather people upgrading to 4.08 and never realized it's just for 6MTs, now I know , thanks for clearing that up
Going from the 7at 3.3 gears to 3.69 is more like 6mt going to a 4.08. 3.90 a little more aggressive but, in my opinion, is the perfect gearing for the 7at.
Look at my reply right above ^
Old Nov 17, 2014 | 12:45 AM
  #35
alfredo24pr
The 4.08s are a simple swap and relatively cheap for the 6MT, but not so much for the 7AT.
Old Nov 17, 2014 | 04:38 PM
  #36
conkus805's Avatar
conkus805
That's true because the 7at guys have to buy a 6mt pumpkin.
Old Nov 17, 2014 | 04:40 PM
  #37
conkus805's Avatar
conkus805
Yes, but you need to make sure it's a 3.90 gear in the diff. I have read conflicting things about the vert diff's having 3.90 gears. Some say it's a 3.3 like every other auto.
Old Nov 17, 2014 | 04:58 PM
  #38
2013 Infiniti G37 Convertible Specifications | Infinitihelp.com
I had a 2010 Vert 6MT for a few days some years ago. That car was heavy, and you knew it every moment you were driving. The only way they could get more grunt out of that car while having the identical drivetrain is to shorten the gear ratio.
Also back in 2010, I was interested in the new Mustang 5.0 6MT. Back then (or still?), Ford offered a rear-gear set-up in no less than three different configurations. So back to back, I test drove the tall gears, and then the short gears. The difference was amazing. The tall gear setup was more livable in 6th on the highway, whereas the short gear setup was a monster in the low end, almost too much, IMO.
If your car is a DD on the highway, I'd stay away from short gears. But if your car is more of a hobby vehicle, and you really really like throwing it around at lower speeds, then short gears FTW. 4.083 gears are my 2016 mod, and I'm seriously looking forward to it.
Alfredo is a student who lives on an Island. Get the short gears as your next mod, buddy. I'm pretty sure you won't regret it.
  #39
PongSanity's Avatar
PongSanity
AT or 6MT? Start a thread, chronicle the process and results.
6mt coupe. Should be a direct swap. No other parts necessary besides oem seals and bushings but I'll start a thread when I'm installing the gears. Look at those bad boys waiting to kill some tires in first gear.
Old Nov 17, 2014 | 06:00 PM
  #40
ScrewstonNismo's Avatar
ScrewstonNismo
So, from what I've read here - Correct me if I'm wrong - For a 7AT, you can swap the 7AT LSD diffs with no trouble, plug and play. But, for the G37S 6MT Vert Diff (3.916) to be put onto a 7AT car, there are modifications needed? Sorry for my ignorance but, can someone dumb it down for me? All this info has me a bit lost
I'd like to have the G37S Vert 6MT Diff on my car so that's why I ask.
Old Nov 17, 2014 | 07:12 PM
  #41
alfredo24pr
For the vert, the G37 6MT is the only one with the 3.9 from what I read.
Infiniti G37 coupe, sedan and convertible technical information
Modifications are also needed to fit the 3.6 from the 6MT to the 7AT.
Old Nov 17, 2014 | 07:58 PM
  #42
ScrewstonNismo
Could you tell me the specific modifications? Is it just the driveshaft flanges? Or do I need a new driveshaft too?
Old Nov 17, 2014 | 08:25 PM
  #43
alfredo24pr
I'm also still learning about the exact details of this mod. I do know that a new driveshaft is not needed although I read some vibration issues, but I'm not sure how that happens.
Old Nov 18, 2014 | 12:19 PM
  #44
skeener's Avatar
skeener
Here are my pros and cons for these mods:
1. Short Tube Headers: Completes my exhaust and more "exotic" sound? Worried about possible rasp and loss of power. Needs retune for gains (if any)
2. 3.9 gears: Would wake up the car. Worried about issues with cruise control, vibrations, etc. Cost of parts and labor. Might want a CF driveshaft upgrade.
3. Throttle Body bored to 63mm: More HP and TQ. Needs retune. Not sure about any other cons.
Not sure about any other performance mod.
Driving (high performance) school?
Old Nov 18, 2014 | 01:49 PM
  #45
alfredo24pr
No need for that because, first of all, I only drag race like once every 3-4 months and as for circuit racing, the tracks here suck and do not motivate to take my car.
If I lived near Willow Springs or something similar, then my build would already have sway bars, lowering, and an oil cooler.
Before having this car, I didn't mind my island. Now, I hate it. I feel that every bad road (which is 85% of the roads here) is slowly killing my car and there are no tracks that allow me to really feel and bond with my G37.
