Considering buying this 2010 G37S, need some help
Old Mar 28, 2014 | 08:44 AM
Originally Posted by 00 SS
Yeah we went off the deep end and traded! We took the Forgestars and system out of the car and kept what we wanted. We absolutely love it. Not as fast as the 5.0 but it does feel good for a high 13 second car.
We did do research and noticed that the Mustang and G37s share the same lug pattern and similar backspacing as what we currently have (staggered)
- Rear: 18x10 , backspacing 7.1" (181mm) and +42mm (1.7") offset.
- Front: 18x9 , backspacing 6.4" (163mm) and +35mm (1.4") offset.
It should fit?
Those should fit, just be careful around those big front calipers until you're sure they'll clear. The spoke setup on those wheels looks like they have a lot of room behind them. If you want to be 100% sure prior to putting them on you can use this template (just tape it to some light cardboard), might be better knowing ahead of time~
http://www.conceptzperformance.com/i...akeoutline.pdf
Thedbarz
33
Feb 9, 2016 12:05 AM
maybeg37
Sep 8, 2015 02:33 PM
regimelife
Aug 18, 2015 04:46 PM
pcwd
Aug 12, 2015 06:54 PM
asato3
Aug 7, 2015 08:45 AM
