Sedan Chat Thread
Old May 1, 2016 | 04:35 PM
  #10291
slartibartfast's Avatar
slartibartfast
Originally Posted by Gregor12
Anyone in here have any experience with installing 370z suspension on your cars? Picked up nismo struts and springs for the low lol I'm thinking about just installed into the shocks and using my eibachs
1) Direct bolt-in
2) Shoulda posted in the Brake and Suspension forum
3) OE Z springs are softer rate than OE G Sport springs but don't how they compare to your Eibachs. You have to remove the spring from the front coil-over assembly to use just the shock, it would be simpler to keep the Z spring on the Z Damper and just swap the rear spring with the Z part.
Old May 1, 2016 | 06:35 PM
  #10292
I swear to god, lately it's been feeling like a chore using a manual transmission. Hoping the STS sparks a renewed positive energy into the whole thing. It's May now... tomorrow I'm going to schedule a date for the install.
Old May 1, 2016 | 07:43 PM
  #10293
Mik3G37S's Avatar
Mik3G37S
I think it's safe to say that you're getting old John.
  #10294
Lego_Maniac's Avatar
Lego_Maniac
Experience? I have 370Z Koni shocks installed. It fits. I'd probably keep your sedan spec Eibachs, just because they're matched to the sedan.
Old May 1, 2016 | 10:27 PM
  #10295
Gregor12's Avatar
Gregor12
1) Direct bolt-in
1. I heard I'll have to cut off the bolt that's tacked to the rear shocks because ours is different, so thats good news haha
2. I would've but I don't like starting threads for questions that can be easily answered in a chat thread. I will post a DIY type thread.
3. I Agree. I'll be keeping the eibachs most likely. As for it being easier, i don't mind compressing the springs and swapping them.
Thank you, I think I'll be doing that. How do you like the konis?
Phil
Old May 2, 2016 | 10:11 AM
  #10296
ColumbiaSkinny's Avatar
ColumbiaSkinny
On a scale of 1-10 what's the difficulty of installing Hotchkis sway bars?
Could i do it by myself or would an extra set hands be much easier?
Old May 2, 2016 | 10:14 AM
  #10297
Gregor12's Avatar
Gregor12
After you get it in the air id say it's a 2
Old May 2, 2016 | 10:27 AM
  #10298
Depends what "1" and "10" represent. But mostly it depends on whether you're standing under the car, or crawling under it.
Another way to frame an answer to your question is: if I had a lift, or if I were younger. Because tools can be bought, and experience can be had on the fly.
And yet another way to look at this project: installation is likely a charge of one labor hour, so $100 give or take.
Old May 2, 2016 | 10:45 AM
  #10299
qmantran's Avatar
qmantran
It's the easiest performance mod you can do to your car that makes the biggest difference.
You don't need another set of hands at all, but you can if you want.
Old May 2, 2016 | 10:49 AM
  #10300
ColumbiaSkinny
Cool, appreciate it. Thought it would be best to ask before i got into something i've never done before....
Old May 2, 2016 | 10:51 AM
  #10301
ColumbiaSkinny
I'll have to crawl under the car unfortunately....
Old May 2, 2016 | 10:52 AM
  #10302
ColumbiaSkinny
What are you doing next weekend? lol.....
Old May 2, 2016 | 10:54 AM
  #10303
On a scale of 1-10 what's the difficulty of removing the entire center/armrest console?
Old May 2, 2016 | 10:59 AM
  #10304
ChinkyChoy's Avatar
ChinkyChoy
I m going to say a 2-3 because you have to unbolt some of the exhaust pipes for the rear and if they are rusted good luck...
I did the fronts no problem but the rears were a total pain in the *** so I waited till I put my ARK CBE in and cut the bolts on my OEM exhaust
Old May 2, 2016 | 11:12 AM
  #10305
ColumbiaSkinny
My exhaust bolts weren't bad getting off when we installed my CBE. I've got around 5k on it now.
The under side has never seen any road salt thankfully and my car only has 21k miles on it. It looked real good up under there.
I haven't looked under the rear end where the sway bar is yet to see what i'll be getting into. I guess i should to get a better idea....
