Sedan Chat Thread
Old Mar 26, 2015 | 10:32 AM
  #6241
AroundTheG37's Avatar
AroundTheG37
Well my front passenger side rotor runoff is bad causing alot of jitter/shutter and rather than resurfacing I fig now would be a great time to invest in slotted/drilled rotors...biggest question is what pads have you guys been using that's not causing any noise (squealing, screeching, etc, and 2 that are low dust? Thanks
OEM.
Old Mar 26, 2015 | 10:43 AM
  #6242
Lego_Maniac's Avatar
Lego_Maniac
Will be doing slotted/drilled rotors, stoptech SS lines, and the one kit I am looking at they do offer it to come with the POSI quiet performance pads
You realize drilled rotors are a downgrade, right?
Old Mar 26, 2015 | 11:04 AM
  #6243
ChinkyChoy's Avatar
ChinkyChoy
i went with slotted rotors I felt like the drilled and slotted were kinda overkill considering I wasn't really tracking the car much
but I went with the posiquiet pads or what ever they are called
Old Mar 26, 2015 | 11:13 AM
  #6244
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
to each their own....I've read 1000's feedback that drilled could potentially crack after use or long periods on track use and Ive read ppl who've had them for 100k miles with 0 issues. Bottom line is my car is a DD, that I track 2-4 times a year in the quarter only. The slotted/drilled option was more for show imo with the use I will get out of them.
However, after reading more about the stoptech SS lines and crappy routing option or lack there of...I believe I am wanting to go with the Goodridge SS kit and maintain the same oem mounting
Old Mar 26, 2015 | 11:36 AM
  #6245
Lego_Maniac
It's not just the propensity to crack
Drilled rotors have less surface area because they have a bunch of holes drilled in them.
Less surface area = less area for the pad to contact = less friction = increased stopping distances
Drilled rotors have less mass because they have a bunch of holes drilled in them.
Less mass = greater heat retention = increased fade
Blanks or slotted are your best bets, but it's your car.
Old Mar 26, 2015 | 11:40 AM
  #6246
Mik3G37S's Avatar
Mik3G37S
Very well stated sir ^ I agree 100%
Old Mar 26, 2015 | 11:53 AM
  #6247
G37Xtreme's Avatar
G37Xtreme
So is there a fine line between when slotted is worse than full faced? With slotted, you have less weight, and less surface area too. I guess there's a point where the added benefits of of heat dissipation from the slots are counter productive. It is for heat dissipation that we have slotted rotors right?
Old Mar 26, 2015 | 12:02 PM
  #6248
doctavic's Avatar
doctavic
New to the site!
Hey all! New to the site, just got my (new to me) 2011 G37x. Got it as a CPO, 55k, navigation. Can't get enough of it. Spent the last two days looking through the site for what to do to it! Paddle shifters up first for sure.
Old Mar 26, 2015 | 12:17 PM
  #6249
Lego_Maniac
Slotted rotors tend to be more efficient at moving water away from the rotors than blanks. Some people argue they scrape any deposits off the pads.
I'm a fan of blanks, personally, but slotted are fine, and don't have the disadvantages of drilled.
Old Mar 26, 2015 | 03:20 PM
  #6250
Baby Jumpman's Avatar
Baby Jumpman
I'm having the same problem with my stock rotors although I've read they are prone to warping. My gas pedal vibrates after I hit a certain speed. I think I'm going to go with some slotted rotors. Also what are some low dust pads? The ones im running now dust like crazy and that reverse squeal is annoying.
Old Mar 26, 2015 | 03:28 PM
  #6251
Lego_Maniac
Pad deposits
Old Mar 26, 2015 | 03:31 PM
  #6252
Pad deposits
Some times is easier to just give in and acknowledge that the world is flat, like a pancake.
Old Mar 26, 2015 | 03:35 PM
  #6253
ZOSTER33's Avatar
ZOSTER33
I think you've got this part of it wrong Lego_maniac "Less mass = greater heat retention = increased fade" drilled rotors help the heat and gasses escape which means less brake fade. Unless I didn't read this right and you were referring to stock rotors.
Advantages of Cross Drilling or Slotting Rotors
Drilled Brake Rotors - HowStuffWorks
Old Mar 26, 2015 | 03:46 PM
  #6254
Baby Jumpman
Pad deposits
How would I fix that? Get the rotors resurfaced?
Old Mar 26, 2015 | 03:56 PM
  #6255
Lego_Maniac
Rotors need to do 3 things
1) Create friction with the pads
2) Absorb heat created by #1
3) Cool down
Drilled rotors are bad at 1 and 2. While they might cool better than blanks, they need to, because they are going to be hotter since they have less mass to absorb the heat created by the pad contact during braking.
Brake cooling ducts--like are available for the 370--would do more for cooling than drilling holes in your rotor.
