Sedan Chat Thread
Old Aug 7, 2014 | 07:39 AM
  #3511
Interesting, but I'm not sure those will work. The rears adjust from a window on the side of the shock using an allen wrench.
Oh.
Honestly though, I suspect these will be like my sways where I set them once and forget about them. Probably full soft on the fronts, and one sweep from full soft on the rear.
I completely agree. However, you need to get that happy place first, before you walk away. And with strut damping, there's a wide range of options.
Being on the side, can you reach the rear adjustment from the wheel well after lifting the car, or removing the rim?
Old Aug 7, 2014 | 07:41 AM
  #3512
Paratrooper's Avatar
Paratrooper
I'm really digging the TSW Interlagos 19x8.5/9.5. Would a rear 19x9.5 et41 look right? Everyone seems to man up to 10+ rears but the Interlagos only comes in 10.5 et27 and no 10¨
I'm running 19x9.5 in the rear with +40. Its flush and im dropped on eibach springs.
Old Aug 7, 2014 | 08:24 AM
  #3513
Lego_Maniac's Avatar
Lego_Maniac
I'm not sure. In theory, yes, and on my Firebird you just jacked up the car took off the wheel and adjusted it. But, these were designed for the 370z so I dunno
Old Aug 7, 2014 | 08:32 AM
  #3514
If the Konis have the adjusters similar to my coilovers (also on the upper side of the shock tower) you can get up there to adjust w/ just a jack of the rear tire.
Old Aug 7, 2014 | 08:35 AM
  #3515
warped ideas's Avatar
warped ideas
A quarter past stripped
Okay, so I'm thinking that I would like to put on some Hotchkis sway bars but I don't know much about the installation. How difficult is it and will the car need to be realigned AGAIN?
Old Aug 7, 2014 | 08:47 AM
  #3516
No realignment necessary. Rears seem easy enough, although easier if you lower the mufflers a little. Fronts are a bit more difficult. Always easier on a lift rather than crawling underneath. And even easier still to take it to a mechanic (or Newt).
Old Aug 7, 2014 | 08:53 AM
  #3517
ChinkyChoy's Avatar
ChinkyChoy
The install is very very easy I did it my self its way easier if you have the car on a lift. the rear sways youre gonna have to take part of the exhaust off if I remember correctly cause it goes under one part and over the other unless that's only the X :P
Old Aug 7, 2014 | 09:10 AM
  #3518
Lego_Maniac
You dont need to realign it.
You're basically taking off bolts, removing parts, putting in new parts, and bolting them back to spec.
You need to lower the rear mufflers as was mentioned. And you need to remove most of the front under belly tray to get at the front bar.
If you dont mind crawling around on your back under your car, its pretty easy.
Old Aug 7, 2014 | 09:18 AM
  #3519
Paratrooper
If you go hotchkis, sale me your eibach sways! Just going off your sig "pro comp kit".
Old Aug 7, 2014 | 09:39 AM
  #3520
alfredo24pr's Avatar
alfredo24pr
I hope so lol. Im waiting on those same wheels, but on 18x8+35 and 18x9.5+40.
The interlagos are a lightweight wheel. Most 10+ are usually over 30 lbs.
If you do not mind the big weight gain, then there are lots of other wheels similar to the interlagos.
Old Aug 7, 2014 | 09:54 AM
  #3521
nishfish871's Avatar
nishfish871
I do mind the weight issue...that's why Interlagos interested me. I want a balance of better performance and look. The wallet becomes the biggest issue.
Old Aug 7, 2014 | 10:20 AM
  #3522
ttv36's Avatar
ttv36
Race, repair, repeat.
Did some experimenting last night. Not sure how I feel about it.
Old Aug 7, 2014 | 10:51 AM
  #3523
Diode Dynamics's Avatar
Diode Dynamics
It would look better if it was glossy, but overall still pretty cool!
Nick C.
Old Aug 7, 2014 | 04:44 PM
  #3524
original sin's Avatar
original sin
Tried to debadge my trunk today.
Took off most of the glue, but now I have this much harder glue left over. Anyone have any tips?
I tried goof off, but I didnt soak it very long. Some people mentioned to clay bar it.
Old Aug 7, 2014 | 04:45 PM
  #3525
ttv36's Avatar
ttv36
^ Goo gone and finger nail. Then polish and wax it.
