Bumper thing on muffler
Old Oct 4, 2013 | 02:14 PM
Paceship's Avatar
Paceship
Hey, what's those hard round rubber things attached to the front of each muffler with two bolts? I can't think of any reason or use for them.
Old Oct 4, 2013 | 02:23 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
they are the rubber hangars. It is what suspends your muffler/exhaust assembly. If they were made out of metal, it would rattle and vibrate. The rubber allows a small amount of play to your exhaust without letting it damage anything.
Old Oct 5, 2013 | 03:45 AM
muyrec's Avatar
muyrec
Sound dampers. Removes any vibrations in the exhuast. You also have 2 more on the Y-pipe.
Old Oct 5, 2013 | 05:38 AM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
He is 100% right. I work at the Toyota plant in Georgetown KY and I install exhaust systems for Camrys and Venzas and we use those hangers from the front pipe all the way to the tail pipe. It gives the exhaust system some give when the car hits a bump.
Old Oct 5, 2013 | 09:15 AM
I have always wondered: why does the exhaust piping near the rear if the Camry hang so darn low? They look almost like they're broken.
Old Oct 5, 2013 | 05:54 PM
MalbecG37S's Avatar
MalbecG37S
I guess it depends on which rubber things are being discussed. Both responses are correct.
The one that the muffler is hanging from - well...it's the muffler hanger.
The one that is just kind-of there - it's the vibration damper...not exactly sure how that works, but yeah - it's there. And as mentioned - there are 2 more on the Y-Pipe...
Old Oct 5, 2013 | 06:04 PM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
I've never really noticed that before. You've sparked my curiosity. I'll have to look into it.
Old Oct 5, 2013 | 06:26 PM
Drive behind any late model Camry or Lexus ES. You'll see how low it hangs below the car.
Old Oct 5, 2013 | 10:37 PM
Paceship's Avatar
Paceship
THANKS!!! I know of the rubber hangers, so that was not my question. Your description of those things that are "just there" attached to each muffler and Y pipe as sound dampeners makes sense. Any idea HOW they work?
Old Oct 6, 2013 | 03:44 AM
MalbecG37S's Avatar
MalbecG37S
I've wondered the same. They do not support anything....they are just 'hanging out'...
Old Oct 6, 2013 | 05:52 AM
speedracer g37's Avatar
speedracer g37
They've been that way since the early 90's when they up sized and rounded out the car...92 or 93. Passenger side, right in front of the wheel, the pipe dips way down. It almost looks like it would scrape going over a speedbump.
slowbird
Aug 3, 2023 07:54 PM
Broski28
Feb 26, 2016 12:26 PM
Topher9425
Dec 1, 2015 03:00 PM
G37 IPL Bryan
Sep 15, 2015 04:40 PM
