3 led fogs?
3 led fogs?
4 x 3LED 3W White Tiny Daytime Running Light Eagle Eye Driving DRL Fog Lamp 12V | eBay
Look similar to the stock ones when running I'd say.. Should I add after market fog lights or just do the 3 led on either side vertically.
Sam
Sam
Could these work also http://www.ebay.com/itm/6-x3W-LED-Eagle-Eye-Backup-Light-Fog-Driving-Lamp-Car-ATV-Motorcycle-white-Light-/400525884258?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d4133fb62&vxp=mtr
I think qpham45 has the best looking individual LED setup, quality parts and can be placed in any pattern for a nice custom look~
https://www.myg37.com/forums/g37-sed...-drl-fogs.html
These: http://www.ebay.com/itm/NEW-INFINITI-G37-SEDAN-FACTORY-LED-DAYTIME-RUNNING-LIGHTS-/190893883067?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AG37&hash=item2c72297ebb&vxp=mtr are nowhere like those though. I've had them on 2 sedans. I'd be interested to see how bright these are, although I'm a bit put-off by the squared corners as our cars don't really have these kinds of angles at all on the front.
Sam
Sam
'4 x 3W LED Daytime Running Light' Is it 4 LEDs per unit @ 3w each? I see 3 LED per side.
'Number of LED Bulbs(each): 3' Ok we got that cleared up LOL.
'Connect wire length: enough for fitting' Huh? Good to know.
Anyone want to hazard an email them to clear some things up?
Might want to check out his neutral and negative feedback though.
Nice price tag. Im assuming you gain 2 mpg and about 10whp with install lol.
This ad is a bit of a hoot:
They do look similar to stock just w/o the fogs. I could maybe buy those and fogs and save 500
hey guys, I've been laying low for a while. Those LED that they sell on ebay....DO NOT BUY THEM! They are a huge safety hazard. I had ordered like 3 pairs to see what they were like and took them apart. Its made in China so all i can say is that you definitely get what you pay for. The wiring they use is tiny. I think its smaller than a 22 gauge wire. Then the resistor they use isnt even made for the power output of any car battery. So in a few weeks down the line those bulbs will blow. On top of that they wrapped TISSUE paper around both negative and positive wires after they soldered them onto the LED bulb. If those wires cause a spark the tissue paper will catch on fire easily.
In my opinion you should make them yourselves. You can get all the wires, bulbs, resistors, heat sinks, shrink wrap anywhere they sell electronic components. The material cost for the set up like mine (4 LED setup) ran me about $80. Then you will be required to find a way to mount them, wire them, drill the openings for your lights. You can make your own mounting plate or even use some kind of silicone. Its all up to you and your creativity.
timc00k
Feb 15, 2017 09:15 AM
