Help wanted with a glove compartment rattle.
Old Sep 4, 2013 | 06:24 PM
the rever's Avatar
the rever
The glove compartment on my 2009 G37x has gotten a bit loose, and does not close tightly enough to prevent a rattle. Ooh, it bugs me. Does anyone know how to tighten it up to the dash?
Old Sep 4, 2013 | 07:05 PM
glennp_2012's Avatar
glennp_2012
That's a standard feature on all G's lol. I took mine to the dealer and they put a sound absorbing strip which did absolutely nothing. Anyway, I traded the car in and so far no rattles on the new one but then again I only had it for a week so I will give it time I'm sure the rattles will come.
Old Sep 5, 2013 | 10:28 AM
the rever's Avatar
the rever
Well, I haven't really had much difficulty with rattles, other than a seatbelt receptacle. But this glove box rattle is beating me over the head. I hope I don't have to go to the dealer to get it fixed. But if no one around here knows how, I may be forced.
Old Sep 5, 2013 | 10:33 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Go to the DIY section of the forum, there's a writeup in the sticky section on how to replace your cabin filter. In it, they show you all the screws that secure the glove box to the dash. I would go in and check to make sure they're all nice and tight before you take it in to the dealer and pay some mechanic 125 dollars to "diagnose" with a phillips head screwdriver.
Old Sep 5, 2013 | 03:45 PM
the rever's Avatar
the rever
Thank you very much--that helped a lot. After watching the video, I tightened a few screws and pressed on a couple of areas that were rubbing together when the door was closed, and that seems to have helped quite a bit.
Thanks for the tip! I appreciate you.
G37xhibeet
Nov 15, 2016 09:29 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
wattles
Sep 30, 2015 09:19 PM
mitchlt
Aug 20, 2015 03:44 PM
