Hood Liner
Old Aug 16, 2013 | 04:17 PM
daonlyillwiz's Avatar
daonlyillwiz
The 370Z has aluminum door panels, too. All of which is to reduce weight. However, you make a valid point that the hood materials are different...
...except by that reasoning, the hood liner dissipates heat in a way that the 370 does better anyway because of the aluminum. Do you really think the hood liner on the G37 eliminates heat rather than traps it? If so, where does it go? IDK man, for me, that goes against conventional wisdom (said the man who is not a physicist.) In fact, I'd take it one step further and suggest the liner isn't just there to deaden noise, but exists to help the engine warm up to operating temp during cold weather.
How about that?
Either way, I'm liking it, and the hood liner has been banished to the attic.
lol agreed, the hood liner just helps deflect/absorb some of the direct heat...i never said it was there to dissipate the heat so sorry for the misunderstanding, and in a way also in a way helps absorb the engine clatter noise. Honestly either way you'll be fine man lol
Personally i think it looks better w/o the liner
Old Aug 16, 2013 | 04:38 PM
Argh! My brain! You're a clever monkey, daonlyillwiz. Take a bow.
Old Aug 16, 2013 | 05:03 PM
daonlyillwiz
I watch too much of The Big Bang Theory lol
Old Aug 16, 2013 | 06:31 PM
twin_snails's Avatar
twin_snails
Thanks for the detailed review Rochester Definitely digging your setup, it looks REAL clean and the black powdercoating > than the blue. I like the look of the GT-Spec better than my Alutec though. Just noticed the G37S logo on the battery box cover. Nice subtle touch there.
Old Aug 16, 2013 | 07:17 PM
rpm&my_G35's Avatar
rpm&my_G35
If i recall the 370z has an aluminum hood where as we have regular sheet metal hoods...so that being said aluminum dissipates heat alot better than sheet metal/steel/iron/etc...maybe thats why they didnt put a liner.
2nd gen G sedan hoods are also aluminum. I had enough stone chips on my 07 hood to be certain. Nice shiny chips for about 3 years...and no corrosion.
Rochester, your car is looking great!
Old Aug 16, 2013 | 07:20 PM
shadow10g37's Avatar
shadow10g37
how do i post my own threads on here can someone help?
Old Aug 16, 2013 | 07:49 PM
00Max00's Avatar
00Max00
Attachment 98311
Dang, we might not need paint at all if all panels were made of aluminum. I love black cars, but I don't mind to have shiny polished aluminum finish.
Old Aug 16, 2013 | 07:55 PM
You're very welcome. I debadged the G37S off my trunk last month.
That's fantastic miscellaneous info. Thanks, rpm! I'll have to whip that out the next time someone (in real life) asks me details about the car.
No. God damn noobs.
Old Aug 16, 2013 | 08:41 PM
Rad_Slinger's Avatar
Rad_Slinger
Dafuq?
Old Aug 16, 2013 | 11:07 PM
LilRocket's Avatar
LilRocket
Originally Posted by rochester
no. God damn noobs.
Old Aug 17, 2013 | 12:11 AM
Collin_95's Avatar
Collin_95
You had one job...
Old Aug 17, 2013 | 12:59 AM
surfwagon's Avatar
surfwagon
Uh.... Try logging in?
Old Aug 17, 2013 | 02:03 PM
Collin_95's Avatar
Collin_95
Turn off you're computer, and never return to the Internet again.
Old Aug 17, 2013 | 10:24 PM
  #29
gsm026's Avatar
gsm026
So ... back to the subject
I didn't see this thread and posted a new one about the lack of intake sound getting into the cabin on my new 6MT. My '09 xS 7AT sounds sweet inside - a wonderful growl when you get on it, nothing when driving softly. I really miss that sound on the new car. I agree with John ... it's too quiet.
I could try his solution - but why would my two G's be that different?? Both cars have the stock intakes, exact same filters, etc. I asked the question in the other post about a sound port in the firewall because I vaguely remembered that from somewhere. Can't find any data on it. Wondering if they left if off the 6MT?
Greg
Old Aug 17, 2013 | 10:58 PM
  #30
gsm026's Avatar
gsm026
Well, I went out with the drop light and found a difference. The '09 has large Helmholtz resonators (tuned sound chamber) below both airboxes. These are connected by a plastic tube to each airbox. The tube connects to a port about 1" in diameter just in front of the filter element. They are not installed on my 6MT. The filter housings are identical, but there are plugs in the ports on the newer car.
Helmholtz resonators are generally tuned to null out intake sound, but I wonder if these were used to increase it?
Greg
