How quickly does the G warm up?
Old Aug 4, 2013 | 05:35 PM
Jlomb436's Avatar
Jlomb436
Hey guys.
Had another question as I'm shopping around at G37's. I had a 335i that used an oil temp sensor to determine the engine temp and usually for the first 5 minutes performance was slightly altered. After 15 minutes of driving it was usually fully warmed up.
Whats your impressions with the G? Does anyone know if it uses an oil temp gauge to determine temp or radiator? I realize that doens't change anything, but I was curious how long the G's performance is altered due to temp.
Thanks!
Old Aug 4, 2013 | 05:41 PM
rks's Avatar
rks
The G37 doesn't have a RMP limiter like some BMWs but I used to allow the car to idle while it sounded like a truck for the first 2 or 3 minutes but now I just start and go but take it easy until the temp gauge is towards the middle. It also depends on ambient temperature.
Old Aug 4, 2013 | 05:45 PM
crazjayz's Avatar
crazjayz
Actually, I've noticed that my G when cold will shift slightly before, or at 3k in D, even when I'm pushing it. Once it warms up though, 4.5-5k is when it likes to shift.
I definitely think the G doesn't have an RMP limiter, but it also knows not to go to hard when cold.
Old Aug 4, 2013 | 05:54 PM
The temperature gauge in the cluster reflects coolant temp. Any car should be allowed to have the oil warm up to operating temperature before driving hard. How long that takes depends on many factors. Ambient temperature, how long since the car was last driven, oil viscosity, and other factors. Generally driving the car gently and keeping the RPMs fairly low for the first 5-7 minutes will accomplish a proper warm up.
Old Aug 4, 2013 | 09:41 PM
scottp2765's Avatar
scottp2765
It does kinda sound trucky for a minute or two glad it's not just mine.
Old Aug 4, 2013 | 09:51 PM
Vizard_87's Avatar
Vizard_87
yeah same here, this morning sounded like a monstah truck
Old Aug 4, 2013 | 11:49 PM
The VQs are the fastest to warm up that I've owned, and damn do they run hot, after a spirited drive it feels like there's an inferno under my hood.
Old Aug 5, 2013 | 11:22 AM
solidsilver's Avatar
solidsilver
Not sure about warm-up time, but in mine it only takes about 30 seconds for that start-up noise to disappear.
Old Aug 5, 2013 | 11:51 AM
Clearly many people don't understand operating temperature of an engine. It can idle in the driveway for an long time and the oil won't reach operating temperature. The coolant will, but that's not important. As I said, a few minutes of normal, gentle driving will warm the oil up to operating temperature. Before this happens, don't beat on the car. This time is when the vast majority of engine wear occurs over the life of a motor.
Old Aug 5, 2013 | 03:19 PM
botlfed98's Avatar
botlfed98
car warms up pretty quick, isn't full performance until it is warmed up.
Old Aug 10, 2013 | 04:14 PM
Adam West's Avatar
Adam West
Exactly. I had an oil pressure gauge in another car and it was interesting to see the car up to temp on the coolant gauge, but the pressure was still reading higher due to oil that wasn't properly up to temp. Once the oil was up to proper temp the oil pressure would settle down quite a bit, especially noticeable at idle where it would read high when cold.
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
obg376mt
Intake and Exhaust
16
Aug 9, 2017 08:28 PM
Chappedj
Sep 28, 2015 03:20 PM
czirrfb
Sep 16, 2015 04:09 PM
