Rattle From Under The Car?
Old Jul 23, 2013 | 01:21 PM
LOLURMAD's Avatar
LOLURMAD
So about 3 days ago I noticed a rattle coming from under the car. It only occurs when I go over small bumps, basically when the car vibrates. Sounds like something is loose. Any ideas of what it can be? I did some research here and people say it's the heatshield.
Old Jul 23, 2013 | 01:23 PM
That's a common complaint, especially at cold start ups.
Old Jul 23, 2013 | 01:32 PM
LOLURMAD's Avatar
LOLURMAD
The thing is it happens when I go over bumps, so its not like an engine rattle but more like something is and vibrating metal against metal.
Old Jul 23, 2013 | 04:21 PM
defektion's Avatar
defektion
Look at your sway bar end links. I had a strange rattle noise when I would drive on choppy roads, bumps, etc. I suspected it had to do with my suspension. Brought it to the dealership and diagnosed that it was my sway bar endlink.
Hope that helps.
Old Jul 23, 2013 | 04:41 PM
LOLURMAD's Avatar
LOLURMAD
It seems like thats exactly what's happening, thanks! But one questions, do dealers care if your car is modded or not? I have exhaust and HFC on.
Old Jul 23, 2013 | 06:29 PM
defektion's Avatar
defektion
I don't think so , but if your G is still under warranty bring it in to your Infiniti dealership
Old Jul 23, 2013 | 11:45 PM
ZOSTER33's Avatar
ZOSTER33
They'd have to prove that your mods was the cause of problem. I've taken my car in for stuff and it has all been covered under warranty.
Old Jul 24, 2013 | 12:33 AM
NJ Torque's Avatar
NJ Torque
Most likley a brake backing plate/splash shield... Jack the car up and hit each tire on the inside with a rubber mallet to isolate the noise.
Old Jul 24, 2013 | 04:39 AM
boydzfv's Avatar
boydzfv
Old Jul 24, 2013 | 07:59 AM
gugarci's Avatar
gugarci
I've had this before and it's back again. Unless I'm bringing in my car for service I've learn to ignore it. To be honest last 2 x I went in for service i forgot to mention it.
Old Jul 25, 2013 | 03:00 AM
LOLURMAD's Avatar
LOLURMAD
If that brake dust plate is what you're talking about, then you're right. Going to take off the wheel tomorrow and see what its banging against and probably just bend it away.
Old Jul 25, 2013 | 08:34 AM
G37 rattle sound - YouTube
Nice, glad your mystery is solved, nothing more annoying than a noise or rattle that you can't ID.
Old Jul 25, 2013 | 03:39 PM
LOLURMAD's Avatar
LOLURMAD
For sure. Hope this helps people with the same issue
Thedbarz
33
Feb 9, 2016 12:05 AM
350zrunnin12s
Aug 9, 2015 09:55 PM
bqbal
Intake and Exhaust
Aug 9, 2015 06:43 PM
reigle9
Aug 6, 2015 02:45 PM
DennisG37
Aug 1, 2015 11:37 PM
