Sedan and exhaust
Old Dec 14, 2012 | 02:57 PM
91ZCpe's Avatar
91ZCpe
Sedan and exhaust
I asked this in the intake & Exhaust forum but I figured I'd ask here as well...
But can you fit the Ark exhaust in the G sedan? I figured the y-pipe could go in the back while the rest goes in the trunk.
Is there enough room for the y-pipe? Is it short enough to fit without hitting the roof?
Any tips and advice would be appreciated.
Thanks!
Old Dec 14, 2012 | 03:22 PM
rks's Avatar
rks
Yes, it's possible. Edit: Are you trying to fit it as one piece? That may be a challenge.
Old Dec 14, 2012 | 04:14 PM
91ZCpe's Avatar
91ZCpe
Nope.
I figured y-pipe could go in the rear and the mid-pipe and mufflers could go in the trunk.
With the y-pipe, the 2 pipes could lay flat on the ground and be adjusted as needed to fit.
Old Dec 14, 2012 | 04:41 PM
kaoticdemize's Avatar
kaoticdemize
48 inches is the y pipe, 44 for the mid pipes and about 38 for the muffler section. Also about 8 inches high for the tips. I know cuz I am trying to ship my ark exhaust and fit it in the smalles box possible.
Old Dec 14, 2012 | 05:36 PM
91ZCpe's Avatar
91ZCpe
Thanks! Would you happen to know if it'll actually fit? I plan on going out there and measuring to see what I'm working with.
Old Dec 14, 2012 | 06:50 PM
kaoticdemize
should, open your pass through and put the base of the y pipe in, then run the midpipes from side to side, and mufflers on top, or in the back seat. Will all fit in the back seat as well.
Old Dec 14, 2012 | 08:38 PM
91ZCpe's Avatar
91ZCpe
Ah I see. It looks like it should. Takes for the help! Good luck w/ your sale.
Old Dec 16, 2012 | 10:38 AM
madeyalook's Avatar
madeyalook
i have the ark exhaust and i transported it (out of the box it was shipped in) to my installers shop
Old Dec 16, 2012 | 02:58 PM
91ZCpe's Avatar
91ZCpe
I ended up picking up the exhaust last night and put the y-pipe in the back seat and the rest in the trunk and still had a lot of room leftover.
Can't wait to get this installed!
Old Dec 16, 2012 | 05:32 PM
bluedevils95's Avatar
bluedevils95
That looks super nice!!!
Old Dec 16, 2012 | 10:41 PM
91ZCpe's Avatar
91ZCpe
Thanks! Not bad for being used, under 1k miles and a couple hundred dollars.
slowbird
Aug 3, 2023 07:54 PM
SkylineG
Intake and Exhaust
13
Oct 3, 2018 07:56 PM
VQCrew
Intake and Exhaust
18
Nov 23, 2015 08:30 PM
Motoboat
Aug 16, 2015 04:47 PM
