Very quick backup camera question
Old Nov 16, 2012 | 04:08 PM
TRich904's Avatar
TRich904
Searched for this on the forum and in my Owners manual PDF file - could not find an answer.
2009 G37s sedan
Does the backup camera have a beep noise for when you are close to an object? If yes, how do you turn the function on and off?
Thank you
Old Nov 16, 2012 | 04:26 PM
OB G's Avatar
OB G
Don't think the rear sensors are part of a different package so as long as you do have the camera it should have that feature. The option to turn it on/off should be in the menu no?
Old Nov 16, 2012 | 04:39 PM
TRich904's Avatar
TRich904
I'll take another look as soon as I leave my office. Didn't say anything regarding turning off a beep/noise on any menu in the owners manual.
Thanks for the input.
Old Nov 16, 2012 | 04:44 PM
shivers's Avatar
shivers
Pretty sure there's a button to the left of the steering wheel next to the trunk button/VDC off.
Tazicon's Avatar
Tazicon
Why would you want to turn that function off? Just curious. I have only heard it a couple of times in the last year and a half.
Old Nov 16, 2012 | 04:46 PM
TRich904's Avatar
TRich904
Sorry, let me rephrase the question properly. My camera does NOT make a beeping noise when I am backing up. I would like it to from now on. Does anyone know how to turn this function back ON?
Haha - Thank you!
Old Nov 16, 2012 | 04:49 PM
Tazicon's Avatar
Tazicon
Ahhhhh I am not sure but I will see if I can take a look tonight.
Old Nov 16, 2012 | 04:50 PM
TRich904's Avatar
TRich904
Thank you Tazicon lol
Old Nov 16, 2012 | 05:16 PM
dv_ous's Avatar
dv_ous
I have a 2012, don't know how much different it is between the 2009. I have the option to turn on/off and adjust the sensitivity of the sensors. As said earlier, if you have the sensors, you should have the options to turn on/off.
Old Nov 16, 2012 | 05:29 PM
telcoman's Avatar
telcoman
2009 G37s sedan
Thank you
I assume you have navigation
Try pressing settings, then guidance. I'm too lazy to get off my a$$ to go look
Telcoman
Old Nov 16, 2012 | 05:55 PM
TRich904's Avatar
TRich904
Just looked again with doing all that. No luck.
Old Nov 16, 2012 | 06:08 PM
mikejg's Avatar
mikejg
The back-up sensors are not part of the back-up camera. They are two separate entities. Do you have the back up sensors on your lower rear bumper? If so, then you should be able to control the settings (beeping, sensitivity, etc). However having the back-up camera without the rear sensors you will not be able to get the beeping.
I believe in the 2010+ years the back-up sensors were part of the premium(?) package. The back-up camera is standard on all models from 2010 and on. I'm not too sure about 2009 though. Just look at your back bumper and you can tell.
Old Nov 16, 2012 | 06:18 PM
Lokosis's Avatar
Lokosis
The backup sensors (sonar) are not part of the backup camera, they're those 4 bumps you have on your back lower bumper.
As for turning them off, like its been said one of the 3 keys on the lower left that turn off the VDC and open the trunk.
As for WHY, i'd guess the only reason you'd wan to turn those off is if you're hauling a trailer and don't want it going nuts.
Old Nov 16, 2012 | 11:38 PM
sniper27's Avatar
sniper27
backup sensors are not available on 2009. only 2010+
Old Nov 17, 2012 | 12:25 AM
bluedevils95's Avatar
bluedevils95
If you have the camera and your looking at the screen how could you hit something
