2010 Base model options vs 2011
Old Aug 4, 2012 | 11:15 PM
blazeplacid's Avatar
blazeplacid
I had a 2004 G35 that I loved until a lady did a U turn right in front of me and totaled it.
Im looking at a 2010 G37 Sedan.
My budget is less than $25,000.
Pretty much set on one I found for $22,900.
I see that some people talk about the ipod feature in the G37.
Does the base 2010 have an USB, AUX, or ipod control or option(s) for these features?
Also it looks like some 2010 sedans do not have the seat warmer controls, only a "blank" plastic circle where they would go. Are the seat warmers a part of a package or are they standard on the Journey?
Are there any standard features on the 2011 base vs the 2010 base?
thanks for the help.
Old Aug 4, 2012 | 11:41 PM
Hotrodder00's Avatar
Hotrodder00
Hey Man,
Did you check the center counsel for the USB port? It's under the armrest in the compartment....I believe that was the only place they ever put the ports, but I could be wrong.
Old Aug 5, 2012 | 01:19 AM
InfiniteSmoke's Avatar
InfiniteSmoke
^ The ports are under the armrest.
For the most part, seat heaters, memory seats, sunroof, adjustable steering column (mechanically), rear view sensors (as in your back up display will have the measurements, but the actual sensors to sense it is different).
Couple of things I can think of you should check and see if you have them.
Hope it helps! Good luck! Post pictures if purchase goes through.
m3clubracer
Sep 11, 2016 09:01 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
drewfinity
Sep 8, 2015 09:10 PM
maybeg37
Sep 8, 2015 02:33 PM
Ricio1991
Aug 27, 2015 10:17 AM
