Shots of mod in progress
Old Jul 12, 2012 | 06:39 AM
ashmostro's Avatar
ashmostro
Originally Posted by alanz
Does Takeda tube has the same diameter as the stock?
Only where it matters- at the MAF sensor. The tube necks down temporarily at the sensor in order for the readings to be correct without having to reprogram the ECU to compensate for airspeed. Everywhere else the tubing is 2.75".
I'm assuming that's why you asked
Old Jul 12, 2012 | 09:01 AM
Nice clean "stealth" look, likin' it
Old Jul 12, 2012 | 09:17 AM
alanz's Avatar
alanz
Right on
Old Jul 12, 2012 | 09:19 AM
ashmostro's Avatar
ashmostro
You bet!
Note that the takeda does take a little more care to install correctly to avoid rubbing and vibration that you can hear, but I still recommend it if you are a decent wrench.
Old Jul 15, 2012 | 02:28 PM
Batwater's Avatar
Batwater
The website states this is for a coupe. Why would there even be a difference between a coupe and sedan, it's the same engine right?
Old Jul 15, 2012 | 02:39 PM
ashmostro's Avatar
ashmostro
Its the same intake for both. The information just isn't up to date.
dedmanchan
Sep 24, 2015 11:25 PM
acthesquid
General Tech Questions
Sep 15, 2015 07:31 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
