Service jack question
Old Sep 21, 2011 | 09:45 AM
Chris11LE's Avatar
Chris11LE
Does anyone know the distance from front bumper to the front-center jacking point on a sedan with the aero package?
Im curious if the Arcan jack at Costco can reach from the front and lift the whole car at once, or if the "reach" on the jack is too short.
Thanks.
-Chris
Old Sep 21, 2011 | 01:03 PM
bythabay's Avatar
bythabay
20 Year Member
Thanks.
-Chris
Hi Chris,
I have this jack and if I recall correctly, the lift point should be reachable, however, in the case it is not, all you need is one other jack to temporarily lift the car a few inches from one of the side jack stand points and then you'll be able to slip the costco jack down the center there no problem. I would recommend, however, getting an aluminum jack over an iron one since there will be a very significant weight reduction. The aluminum one is a lot better if you plan to move it around a lot between locations, otherwise the costco one is pretty solid.
stealth210
General Tech Questions
27
Jul 26, 2017 06:48 PM
theKfactor
Sep 12, 2015 09:35 AM
carid
Supporting Vendors
Sep 9, 2015 10:41 AM
Gio37
Sep 6, 2015 02:36 PM
