a/c not cold
Old Sep 14, 2011 | 08:14 PM
Ukraineg37s's Avatar
Ukraineg37s
a/c not cold
Hi i have a 2010 g37s and for some reason when the ac is on anywhere from 72-60 degrees the air just isn't as cold as it should be....anyone know what the problem could be?
Old Sep 14, 2011 | 08:36 PM
cy7878's Avatar
cy7878
may have a freon leak. Happens even in new cars. The dealer will be able to test the temperature and pressure check the system.
Old Sep 14, 2011 | 08:48 PM
clutch5's Avatar
clutch5
Do yourself a favor and buy a $10 thermometer like this one:
Amazon.com: CDN IRXL220 ProAccurate Insta-Read NSF Large Dial Professional: Kitchen & Dining
and get your own temperature reading before going in the dealer. Stick it in a center duct with the AC on and it should read about 40 degrees F within a couple minutes.
That'll save you at least one trip to the dealer since your first trip they'll just tell you nothing is wrong; that's how it is; don't worry.
PS Be sure to check the thermometer accuracy using a glass of ice water. Only takes about 30 seconds to do. The type of thermometer I linked to can be adjusted/calibrated, plus it has no batteries to ever replace. Useful in the kitchen as well.
Old Sep 14, 2011 | 09:18 PM
sniper27's Avatar
sniper27
mine is like an artic blast if i don't set it at 70 or above.
Old Sep 14, 2011 | 09:46 PM
BKG37X's Avatar
BKG37X
Same here, leave mine at 75 (feels like 65)
Old Sep 14, 2011 | 09:51 PM
bat6wc's Avatar
bat6wc
my AC went dead last week. took to the dealer and they are replacing the entire compressor under warranty.
when it was working, im with everyone else...75 degrees means 65 degrees.
Old Sep 14, 2011 | 11:30 PM
zoner's Avatar
zoner
Most powerful AC I have had in any car
Old Sep 14, 2011 | 11:32 PM
JJsBusaRox's Avatar
JJsBusaRox
LOL, me too!
Old Sep 14, 2011 | 11:43 PM
financeman's Avatar
financeman
Mine is cold as ice....regardless of outside temp....have dealer check.
Old Sep 15, 2011 | 12:13 AM
Chekov's Avatar
Chekov
Senior Citizen
I’ve had experience with this, and I agree with clutch5. Putting a thermometer right at a duct should read 40 degrees. If it’s anything higher take your car to the dealer.
Old Sep 15, 2011 | 01:14 AM
cy7878's Avatar
cy7878
Just print this thread and bring it with you. Dealer SA usually won't BS a forum member who did his/her homework because they fear being bashed.
Old Sep 15, 2011 | 07:47 AM
bocaytomas's Avatar
bocaytomas
They should be able to replace it, considering our AC is meant to freeze our a**es off!
Old Sep 15, 2011 | 10:21 AM
KLB's Avatar
KLB
How cold is it outside?
Old Sep 15, 2011 | 12:59 PM
rpm&my_G35's Avatar
rpm&my_G35
Like everyone else, both of my 2nd gens have extremely good, cold AC.
I don't think you need to get a thermometer. If the dealer tries to tell you yours is normal then all he has to do is prove it by demonstrating it in one of the many others he has on the lot.
The outdoor climate will have an effect on the automatic fan speed which will have an effect on how it feels in the cabin.
Old Apr 18, 2018 | 08:28 AM
Mattlorentzoe's Avatar
Mattlorentzoe
Instead of creating new thread I figured I’d use this old one.
My Air isn’t cold, no idea where to start troubleshooting at. Tried to fill with Freon and it seems like it will never fill up under hood. Everything was good until I had my radiator and thermostat replaced. Random I know but a/c went out shortly after that... any pointers other than dealer
