When vdc is off, traction is off too.. Thats how you're supposed to drift around..
No, the traction control always remains on. From page 5-54 of the 2011 manual
The VDC OFF switch is used to turn off the VDC system. The VDC off indicator illuminates to indicate the VDC system is off. When the VDC switch is used to turn off the system, the VDC system still operates to prevent one drive wheel from slipping by transferring power to a non slipping drive wheel. The VDC warning light flashes if this occurs. All other VDC functions are off, and the VDC warning light will not flash. The VDC system is automatically reset to on when the ignition switch is placed in the off position then back to the on position.
^ I can confirm from my everyday driving experience that it lets me spin my wheels.. also tosses the *** out and chirps without the vdc lag when shifting!
its a fail safe thing, its like if the button gets jammed and stuck, the on board computer will automatically turn the vdc back on, that is also the reason why after u hold the button u cant turn it off again until u restart ur car.
My car is at the shop now. I did this years ago by removing the fuse (brake light disable or other name), the fuse box next to the left foot rest. it will let you do a burnout.
