does installing viper 5901 / 3303 voids the warranty
Old Apr 26, 2011 | 12:50 PM
lukes's Avatar
lukes
Hi,
couple of weeks back some dumb a** stole all the 4 wheels and tires of my new G37 2010 journey, now i am planning to get 520T(back up battery system), 507M(Tilt sensor), and 506(Audio glass break sensor) installed on my journey. I went to couple of places and they said i first need to get viper brain, because these extra alarms can't be added to the factory alarm, is that true ? If yes, then i am also planning to get either viper 3303 or 5901, but i heard that remote ignition is not fully compatible with g37 and also the range is not good for auto start ? Also, does installing the viper brain voids the company warranty ? Any good recommendations for the installer ? I live in sunnywale, so anything from SFO to SJ is feasible.
Regards,
Lukes
Old Apr 26, 2011 | 07:07 PM
Nonesuch's Avatar
Nonesuch
IIRC, there is a tilt sensor available for the factory alarm?
Technically it is certainly possible to retrofit all sorts of additional sensors to an existing alarm, see this example (for Lexus). Basically all you do is provide power and a delay relay for the sensors, and then wire the output to the existing door open sensor. Now if the car is tilted, the factory alarm thinks a door was opened, and is triggered.
...i heard that remote ignition is not fully compatible with g37 and also the range is not good for auto start ? Also, does installing the viper brain voids the company warranty ?
Yes, remote start on the G37 is problematic.
No, installing a 3rd party alarm does not void the entire warranty on the car. It would void the warranty on any subsystem the Viper is tapped into, and of course if the installer FUBARs your factory wiring harness, Infiniti won't fix that under warranty.
Old Apr 26, 2011 | 08:20 PM
TheLocNar's Avatar
TheLocNar
Don't go Viper. Get this one!
YouTube - Kentucky Fried Movie, Car Alarms
Seriously though... if the installer doesn't botch anything up, you should be fine.
Old May 5, 2011 | 02:13 PM
530itoG37x's Avatar
530itoG37x
Originally Posted by lukes
Hi,
Regards,
Lukes
Hey bud,
Where are you located at? If you are in the Boston area I can refer a great installer!!!
Old May 12, 2011 | 10:35 PM
CsG's Avatar
CsG
I'm checking out places to get viper 5902 installed. FYI in order to start the car...you have to hit the "push to start button" twice then place foot on brake then hit it a 3rd time to start. Shouldn't void warranty unless they torch something
Old May 12, 2011 | 10:51 PM
Modme's Avatar
Modme
I have no idea what you mean by that. I have viper 5902 and I push in clutch and press start.
Old May 12, 2011 | 11:11 PM
kool_yaar's Avatar
kool_yaar
i have the inferior 5701 and i too just push in clutch and press start once, maybe an install issue.
Old May 13, 2011 | 12:23 AM
maxfinity's Avatar
maxfinity
HUH... I have the 5902 and all i have to do after I remote start the car is press the start button twice to put the ignition in the ON position and Im off.
Old May 15, 2011 | 02:16 PM
kool_yaar's Avatar
kool_yaar
im thinking about upgrading my 5701 brain to 5901 or 5902, i did a lot of online research on it and it seems that changing the remote and antenna to the newer one is super easy (the 5701 2-way remote has an issue where it east up the battery within days). However i was wondering if some one knows for SURE if the new brain would be a straight swap into the existing wired harness of 5701??
I looked at their wiring diagrams and they seem same to me but i want to confirm before i drop another $250, i want a straight swap so i dont have to pay for install again... thanks for any help in advance
Old Aug 25, 2011 | 11:26 PM
Chivas11's Avatar
Chivas11
Hello everyone, does anyone know of any installers in So Cal or around San Diego area that can install a remote start alarm, possibly the viper 5902? Im interested in a remote start for my '10 G37 sport sedan 7at. thanks in advance
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
JakeG37
39
Oct 19, 2015 11:09 AM
Cr0tchf4i
Aug 19, 2015 03:52 PM
cparise
Aug 19, 2015 01:51 PM
aliiin
Aug 5, 2015 10:38 AM
