Has anyone seen this happening???
Old Feb 16, 2011 | 12:01 PM
djayash's Avatar
djayash
In my brand new G37X, I have this problem which the dealer claims in happening on all G37X. The problem is this
I am playing songs plugging my Iphone to the USB Cable, then change the source to DVD or whatever, then come back to USB cable, song doesn't play....It sure plays, but no audio is heard in the sound system...Has anyone encountered this?
Also, I have a remote starter which does not start my vehicle from my home. Dealer says signals from remote starters cannot travel through walls and we should be facing it at the car at all times to start...Then why the hell do I need it?????By the by, it is a Code Alarm Remote Starter system..
Old Feb 16, 2011 | 12:47 PM
Steveo47's Avatar
Steveo47
I have a 2010 g37x coupe and don't have this problem. And I mean your suppost tonpoint the remote towards the car but it should go through walls unless they are made of concrete or something
Old Feb 16, 2011 | 03:41 PM
roots4x's Avatar
roots4x
On the iPhone you may have it conveyed through Bluetooth. Open iPod on your iPhone and select the target from the bottom to "dock connector".
Old Feb 16, 2011 | 03:51 PM
djayash's Avatar
djayash
It works perfectly fine when I plug it via bluetooth...But if It is plugged in via the USB cable, somethings wrong and it doesnt work in the below mentioned scenario...
Old Feb 16, 2011 | 04:01 PM
roots4x's Avatar
roots4x
Right, that's the problem. When you pass through the Bluetooth audio menu, the car grabs the audio from the phone and the phone won't let go of the bluetooth connection until you set it back to dock connector in the iPod app.
Old Feb 16, 2011 | 04:15 PM
djayash's Avatar
djayash
thats a very intresting theory...i cant wait to check that out...will keep u guys posted...
Old Feb 16, 2011 | 04:21 PM
roots4x's Avatar
roots4x
Yeah that happens on my 2011 also and it took me a while to figure it out. It is annoying, but it's nice that you can discretely select one or the other from the phone directly. It'd be nice if the car let go of the bluetooth audio connection when you left the Bluetooth Audio section.
Old Feb 16, 2011 | 05:15 PM
CaptainObvious's Avatar
CaptainObvious
You didn't mention maximizing your remote range, so if you're not already doing this, try it:
Touch the car remote to the underside of your chin and extend your free arm outward when you press the button. This extends the range for all of these types of remotes.
BTW, I also have a Code Alarm on my truck, installed 2002, with remote start, window lowering/upping and an optional? remote antenna installed right above my rear view mirror. I have exceptional range, with obstacles being the reducing factor...
fuzzed
Aug 21, 2020 09:35 AM
linvbro
Aug 22, 2016 01:25 PM
parkern
Oct 1, 2015 10:15 PM
ajosowiecky
Sep 30, 2015 12:15 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
