Quick Oil Change Question.
Old Oct 2, 2010 | 03:27 PM
pro-gadgeter's Avatar
pro-gadgeter
I'm over 400 miles due for a oil change. I can either get an oil change from dealer for 39.95 + tax or I can buy Mobil 1 Synthetic Oil for about 31.99 with free oil filter and pay another 15 dollars to my local repair shop to change it(drain old oil, put new one in, change oil filter). The money isn't a big difference. So would you suggest regular oil change or synthetic oil change? If you know, whats the difference between the two?
I want to get it changed this weekend, I have a very busy schedule so its either this weekend or put off till next weekend.
Btw, dealer is charging $90 for synthetic oil...
Old Oct 2, 2010 | 03:43 PM
james0076ss's Avatar
james0076ss
I would go with Synthetic at the local place. Syn is just better oil to begin with. just google search it. Just remember to keep you receipts when having it done else where.
Old Oct 2, 2010 | 04:16 PM
needsoju's Avatar
needsoju
The main difference without going into details, synthetic oil allow you to go many more miles before oil change compare to regular oil.
Many folks use regular oil just fine. I think this is preference among drives which oil they want to use.
I would suggest you use synthetic oil change.
Holy cow, $90 ... even ester oil is not this expensive. They must be using AMSOIL Synthetic oil...
Dude take it to local shop..
Old Oct 2, 2010 | 05:16 PM
sniper27's Avatar
sniper27
$90 is with labor i'm sure. my audi dealer used to charge between $70 - $90 for synthetic oil changes, which is required on the Audi.
Old Oct 2, 2010 | 06:42 PM
jb606's Avatar
jb606
If you trust the local place do it. Just keep your receipts and have the place note the mileage, just in case you need to have warranty work done at the dealership.
Old Oct 2, 2010 | 07:12 PM
xixonmn's Avatar
xixonmn
Changing oil is very simple. Just bring it to a local shop & save some money.
Old Oct 2, 2010 | 09:55 PM
KLB's Avatar
KLB
Do you want to change your oil every 3750 miles or do you want to go longer? If you want to do it at 3750 get the regular dino oil at the dealer. If you want to go longer get something else. I would suggest you not get Mobil1 though. There have been a number of people that have had bad results with it in the G37, myself included. I had two done, both with less than stellar results.
You can see some of the results of oil analyses here
Blackstone Oil Analyses
Old Oct 3, 2010 | 12:30 PM
pro-gadgeter
Well I'll be buying the oil myself from autozone and then give it to the repair guy to change it for me... So will the autozone receipt alone do it or do i have to get a receipt for like 10 dollars from the dealer too? I can always say i changed it myself. Would you guys recommend using the mobil 1 oil filters or oem filters?
Old Oct 3, 2010 | 01:08 PM
xixonmn's Avatar
xixonmn
You can ask the repair guy/shop for a receipt.
I use Bosch premium oil filter. Cheaper than Mobil 1 but still very high quality.
Oil Filters - Dissected - Chrysler 300C Forum: 300C & SRT8 Forums
https://www.myg37.com/forums/engine-...otsa-pics.html
Old Oct 3, 2010 | 02:31 PM
Mobil1 filters are better than oem, so are the Bosch, Wix, PureOne filters.
Old Oct 3, 2010 | 03:12 PM
jb606's Avatar
jb606
Keep all the receipts. You'll have the burden of proof if you need to have any work done at the stealership...dealership.
Old Oct 3, 2010 | 11:27 PM
CougarRed's Avatar
CougarRed
Can't go wrong with the Purolator PureOne. Part #14612 matches OEM size perfectly.
As for choice of oil, the only thing I'd stay away from is Nissan Ester oil. Personally, Mobil 1 is not my choice although a lot of people use it.
czirrfb
Sep 16, 2015 04:09 PM
sharmelan
17
Sep 14, 2015 03:18 PM
si_driver
Sep 12, 2015 10:38 PM
