Anyone has the factory impact sensor alarm?
Old Apr 28, 2010 | 11:24 PM
antirice's Avatar
antirice
How sensitive is it? It looks like a pretty cheap option. Will this be simple DIY add on?
Old Apr 28, 2010 | 11:32 PM
CuddysG37's Avatar
CuddysG37
I have this on my car. The dealer added it on before I took the car. Shouldn't be too hard to add on afterwards. The sensitivity is adjustable to 11 levels, I had mine set in the middle. I haven't gone bumping my car to try to set it off but it also is a glass breakage sensor as well, something I don't plan on testing.
Old Apr 29, 2010 | 02:38 AM
lokitiw's Avatar
lokitiw
I can tell you this much, it is very sensitive. I had the dealer set mine down to #7 and I know it works well. Well worth it. I believe that there is someplace in the "search" that tells how to set it. I had the dealer do it as I did not want to get involved with it.
Old Apr 29, 2010 | 02:21 PM
J2S2M's Avatar
J2S2M
How much more for this option to those you who already have this?
Old Apr 29, 2010 | 04:05 PM
antirice's Avatar
antirice
http://infiniti.sewellparts.com/acce...-2010-419.html
It's only about $65. So cheap that's why I want to get it. I searched around a bit and although it's not a direct plug and play, the install doesn't seem that difficult.
Old Apr 30, 2010 | 01:25 AM
lokitiw's Avatar
lokitiw
When I ordered mine it was $130.00 bucks. I looked at it as if I got an after market installed it would have been around the same.
Old Apr 30, 2010 | 08:55 AM
Kidcane's Avatar
Kidcane
Florida G Club
To the OP, what year is your car? I dont think it works with the )08's. Just 09 and up.
Old May 3, 2010 | 05:31 PM
rx794's Avatar
rx794
I had this optioned on my car from the factory, does anyone know how to adjust the sensitivity of it?
Old May 6, 2010 | 01:36 PM
HKSG37s's Avatar
HKSG37s
^^^^^same question.....how is the sensitivity adjustable?
Old May 6, 2010 | 01:42 PM
Blackjack's Avatar
Blackjack
To Adjust:
The panel under the passanger side dash. Use your finger to pull down.
It just three clips to clip on.
<a href="http://s254.photobucket.com/albums/hh110/designerpatrick168/?action=view&current=1-3.jpg" target="_blank"><img src="http://i254.photobucket.com/albums/hh110/designerpatrick168/1-3.jpg" border="0" alt="Photobucket"></a>
<a href="http://s254.photobucket.com/albums/hh110/designerpatrick168/?action=view&current=2-3.jpg" target="_blank"><img src="http://i254.photobucket.com/albums/hh110/designerpatrick168/2-3.jpg" border="0" alt="Photobucket"></a>
Now look up the right in the side cover, the unit is right there.
<a href="http://s254.photobucket.com/albums/hh110/designerpatrick168/?action=view&current=3-2.jpg" target="_blank"><img src="http://i254.photobucket.com/albums/hh110/designerpatrick168/3-2.jpg" border="0" alt="Photobucket"></a>
Old May 7, 2010 | 12:19 AM
HKSG37s's Avatar
HKSG37s
DUH, nowwwww that is totally too easy. I hate when my boss starts up his M3 with a vorstiener exhaust that sounds like a rattle can of spray paint and my alarm goes off because the sound reverbs in my office garage so much......this is the most helpful info I have found in a while.......
Old May 10, 2010 | 12:27 PM
kapyt's Avatar
kapyt
I just found out how sensitive is mine set. I had the car locked, pulled its wiper and released it, the impact caused the alarm to go off. I guess it's set to high sensitivity.
Old May 15, 2010 | 03:41 PM
antirice's Avatar
antirice
Just done installing the sensor. It was very easy to do. All you gotta do is tap three wires to the BCM. Posi taps are included which makes tapping wires a snap (I never tap a wire in my life b4 this)
The sensor doesn't seem very sensitive, I set it to the most sensitive setting, and I had to give a decent kick to the front tire to set it off. For now I just leave it on medium (level 7).
Overall I think this is a good add-on. Very easy to install and it's cheap. I paid about $73 for it.
vamarris
Dec 9, 2018 11:10 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
delfinparis
Oct 8, 2015 06:06 PM
2K1 6T8
Oct 6, 2015 07:40 PM
Irishcurtis
Sep 30, 2015 11:39 AM
