First Oil Change?
Old Mar 28, 2010 | 08:43 PM
Infiniti7's Avatar
Infiniti7
First Oil Change?
i know i mentioned this topic before and just want to make sure i understand. i went to the dealership today to ask about changing my oil because i am about to ship my car across country and i wanted to change it here before i left so i dont have to do it when it comes off the truck. i have almost 2500 miles on my car right now and i have had the car since December 14th. i have had the car a little over 3 months now and was wondering if i should just go ahead and change the oil early for the first time because i was told that the engine eats up more oil the first time because the engine is new and there are also particles and fibers from the engine break in. should i wait for the 3750 mark and wait over 3 months or go ahead and change it a little early? thanks!
Old Mar 28, 2010 | 08:46 PM
cdso's Avatar
cdso
No harm in changing it early. I did my first oil change @ 1200 miles.
Old Mar 28, 2010 | 08:54 PM
Blackjack's Avatar
Blackjack
You are fine to do it now. Won't cause any problems.
Old Mar 28, 2010 | 08:56 PM
dkmura's Avatar
dkmura
20 Year Member
The VQ37VHR does not "eat" more oil when its new. The oil fill from the factory has been in your G since it was manurfactured. As components like piston rings and rod/main bearings wear-in, the oil encapsuates and holds these metallic particles in suspense. This is the rationale behind scheduling that initial oil change a little early.
Old Mar 28, 2010 | 09:24 PM
TheLocNar's Avatar
TheLocNar
To those that brought oil to your dealer, did they give you any funny looks, or were they cool with using it?
Old Mar 29, 2010 | 12:51 AM
Infiniti7's Avatar
Infiniti7
so after i change the oil at 2500 miles when should i change it again?
Old Mar 29, 2010 | 01:06 AM
TheLocNar's Avatar
TheLocNar
In another 3750 or so, just as the manual states.
Old Mar 29, 2010 | 12:55 PM
LightsOut's Avatar
LightsOut
did my first at 1800 and plan on dong the second at 3750, then doing the third at every 5k
switched to syn. motul 8100
Old Mar 29, 2010 | 06:54 PM
Infiniti7's Avatar
Infiniti7
what kind of oil does the dealer use?
Old Mar 29, 2010 | 08:06 PM
hieuster's Avatar
hieuster
it depends on your dealer. my dealer uses valvoline synthetic blend.
Old Mar 30, 2010 | 11:23 PM
kapyt's Avatar
kapyt
So, it's time for me to get my first oil change. I contacted my local dealer and inquired about 1st free oil change. Sure enough it offered me one. I then started asking question whether they will use Nissan Ester oil. Here is the response: We can use it if you would like. We have come to know more about the engines and the only G37 needing Ester oil is the coupe.
Since both cars' engines are identical, is the dealership full of it or it's OK to use whatever oil it has? After reading all oil threads here, I'm hesitant to put anything but Ester or Penzoil Ultra... Thanks
Old Mar 30, 2010 | 11:31 PM
TinsleyC's Avatar
TinsleyC
Use a quality synthetic and you should be fine.
I went with Pennzoil Ultra, but after reading the Pennzoil Ultra FAQ on the BITOG website, I'm not sure the Ultra contains esters, or even needs them. "To ester" or "not to ester" has me confused.
I think you need to open this link with Chrome or FireFox or something other than IE because IE won't display the text -
Pennzoil Ultra FAQ
What it says:
14. Has Pennzoil<SUP>®</SUP> incorporated any type of Esters into the base oil blend for Pennzoil Ultra™?
No ester base oils were used or are required in the Pennzoil Ultra™ range.
Old Mar 31, 2010 | 11:58 AM
kapyt's Avatar
kapyt
Interesting find. I guess this is my dilemma as well whether "ester" or "not to ester." I convinced my service manager to use Ester oil this time. He mentioned that in the future the oil change cost would be about $115 using that type of oil versus normal 5W30 non-synthetic oil which would cost about $65. Sounds a bit high for a non-synthetic oil.
Old Mar 31, 2010 | 01:47 PM
SM_Shadowman's Avatar
SM_Shadowman
$65 sounds way too much for a bulk-dino 5w30 non-synthetic oil change. I'd go somewhere else if you want that -- considering you can get the exact same thing for less than 30 bucks from pretty much any mechanic. Or even most car dealerships.
The Nissan Ester oil itself is expensive. Up to $11-$12 per quart if you buy it yourself.
Old Mar 31, 2010 | 02:17 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
IMHO the ester based oils are no better than anything else. "ester" has no special meaning to me. Mobil1 or Penzoil Ultra is all I'll use
The two times I've had the dealer do it, I bring my own oil and they're totally cool with it. The other times I change my own oil.
