G37 Sedan Spoiler Install
I tried doing a search but can't find a DIY on the OEM spoiler install. Has anyone attempted this on the sedan? I know there is drilling involved which i'm okay with. Just wanted to get some instructions and recommendations on what type of drill bit to use etc etc.
Thanks
Thanks
OEM spoiler install
Just installed an OEM spoiler (K6030-JK6, smaller lip spoiler) this weekend on my 2009 sedan. You do have to drill 5 holes, 3 of which are under the original trunk lid chrome trim piece and 2 are out toward the corner of the trunk lid so your committed once you drill those 2. Final drill size is 5/16 (center punch, then drill 1/8 pilot hole first). The spoiler comes with needed templates and my spoiler seemed to match up just fine with the drilled holes. I took my time and measured twice and cut once and took about two hours total from start to finish with vacuum clean-up for the drill chips and such from the trunk carpet.
Thanks!!
Check this thread, I posted a DIY on toward the end of the thread. You don't need to drill the two outside holes (the ones outside the current chrom trim piece) if you don't want to. These utilize snap plug/clips, the spoiler w/ the inner 4 bolts and double sided tape, along w/ the structural fit of the spoiler against the trunk keeps it very solid.
https://www.myg37.com/forums/g37-sed...5-on-ebay.html
superjoey
31
Mar 22, 2023 11:56 PM
