I have a '11 6mt. I want to know if anyone here drives their cars regularly with the VDC off. If so, what differences or enhancements do you see? Thanks.
vdc allows you to have a little fun without pushing the car to far and ending up in a ditch.
i also dont think people regularly drive with vdc off.. the only time i turn it off is if im going to be stomping on it from a stop and dont want the car to cut power.
vdc @ slow speeds - can get you in a sticky situation when your expecting/needing power. it can also throw you off on turns, you turn with decent power expecting neutral/ a tad oversteer, instead power cuts and suddenly ur pushing like a bulldozer.
vdc @ high speeds - can save you bunz when your pushing it on some back roads or a nice on/off ramp.
i drive with it off, unless im driving all highway. maybe im just used to rwd with out it.
^Lol, I only take it off when Im pushing it...allows the rear end to step out and have some fun! There's a reason it's default setting is for it to be on.
For years and years cars didn't have stability control, or 4 channel abs. Cars did just fine. If you do experience wheel hop, that can cause rear end or other driveline damage.
I push the start button then push the VDC off button... I will however click it back on if I am goign to be on the highway for an extended period of time. I do not drive my car too often though so when I do, it is always for fun!
