Turning off car turning on accessory power
OK, so i turn off the car, but have left the windows open.
With my previous car the electric stays on for 10 minutes to i can open and close windows, play radio with engine off.
So far it appears i have to shut car off.
Press the power button once which turns it to acc BUT CANNOT operate windows
Then if i hit it again all the lights on the dash light up and i can power windows. There must be an easier way.
Also if your playing music there is a delay each time you switch between ON, ACC an whatever the other setting is.
RTFM - That's how it works. In other cars usually the power remains on until you open the door, but the G only has retained power for the sunroof for 45 seconds after the engine is turned off. You need to be in ON mode to operate the windows.
thank you. FYI - I dont have the manual....its a loaner till mine comes in and they didnt include it, couldnt fit it in the glove box
Calvin, check out this site, might help before your car comes in...
http://www.infinitiusa.com/iapps/tec...Manuals_Guides
superjoey
31
03-22-2023 11:56 PM
Lt8Che
91
04-08-2022 04:55 PM
