Climate control slow to heat up cabin
Old Mar 15, 2009 | 08:32 PM
Vyper316's Avatar
Vyper316
Originally Posted by madmax2k1
On cold days I put the temperature to 75 degrees and put the climate control on Auto; the heater takes a very long time to start blowing hot air from the vents, it starts blowing warm air from the foot wells and take another 5+ minutes to start blowing air from the upper vents. Is this normal?
I owned a Nissan Maxima that exhibited this same behavior.
My wife owns a Lexus and the heater start blowing hot air from the vents as soon as I turn the climate control up.
I don't know what the climate is like where you live, but here temperatures can get as low as -35 Celsius (about -30 F) sometimes, and I kind of like the fact that it waits to get warm before it sends air through the vents... Believe me, the only thing that sucks more than -35 degree temperature is having it blown in your face by a fan on a cold engine! Windchill is harsh!
Old Mar 15, 2009 | 10:35 PM
JohnEnglish's Avatar
JohnEnglish
Originally Posted by shumby
ok guys here it is from someone who knows cold . The heater will not start to blow warm air until your engine is properly heated up. Your heater is basically a fan blowing accross your heater core. The car will not flow warm fluid through your heater core until the engine has reached a certin temp. Once that happens you get hot air
Yup, all Nissans/Infinitis are like this. The fan will not start blowing until the engine reaches operating temperature. The only exception is if you put it on defrost.
2K1 6T8
Oct 6, 2015 07:40 PM
Landshark
Sep 29, 2015 11:20 PM
MrRiv
Sep 29, 2015 04:59 PM
dedmanchan
Sep 24, 2015 11:25 PM
SheLLz
Sep 24, 2015 08:02 PM
