G37 - Rattle/tapping at RPM
Old Aug 26, 2025 | 04:24 PM
Jameszzzzz's Avatar
Jameszzzzz
Angry G37 - Rattle/tapping at RPM
Was hoping someone has dealt with this before, I've got a rattle/tapping that has been around for about 6 months now atleast, It seemed to only make the noise on decel around 2300-1700rpm. After playing around with launch control it makes the noise while holding rpm steady too.
Oil has been changed multiple times in the last 5000kms with nothing bad showing up.
EVAP valve has been removed to see if that was the issue, serpentine belt removed to check incase idlers causing the sound.
Have also removed valve covers to look for anything funky in the head however the cams and buckets all look brand new.
At a bit of a loss here with what it might be, unsure if it's possible there's a small crack on the headers making the sound echo however I can't see any soot around them
The car is a 2007 370GT Manual 6 speed it is heavily modified with a turbo kit.
Attached are some videos to hopefully help give an idea
File Type: mov
File Type: mov
ToniVQ
Mar 4, 2024 04:18 PM
ColoradohGee
Aug 23, 2023 11:50 PM
The_Slow_g37
General Tech Questions
May 21, 2023 05:06 AM
SpuuDy
18
Aug 24, 2021 07:34 AM
brrrtpoypoy
Mar 16, 2008 03:21 AM
